RV.Net Open Roads Forum: Fifth-Wheels: Tire change on the road
 > Tire change on the road
dedub
Eastern Wa
Posted: 05/30/12 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
Not a newbie exactly but here's one I haven't really figured out in the real world. How do you really lift these things to change a flat if you can't jack the axle up? Does the "Trailer Aid" lifting device work? I know for sure I can lift it with two jack stands and some four x fours but don't really want to carry all of that. Mines a pretty light unit so that's a bonus...\
HappyKayakers
Black River Falls WI
Posted: 05/30/12 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
I've never had a problem jacking on the axle right under the U bolt.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
fj12ryder
Platte City, MO
Posted: 05/30/12 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
IMO the "Don't jack under the axle" warning is to keep people from sticking that jack under the center or some unsupported area of the axle and bending it. Mainly a CYA by the manufacturer.
I also jack right under the U-bolt. No problems so far.
Howard and Peggy
"Don't Panic"
tvman44
Southwest Louisiana
Posted: 05/30/12 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Been jacking trailers under the "U"Bolt for over 50 years and never a problem. But don't do it anywhere else.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
RAS43
Littleton,CO
Posted: 05/30/12 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
X4 I have had to change a tire on the road twice and used a bottle jack under the u-bolt without any problem. If I would have had to jack up on the frame as the manufacturers state I'd have had to call for road service as it takes too much lumber to get the jack close to my frame aand I don't carry a Trailer Aid-that's what a jack is for.
path1
seattle
Posted: 05/30/12 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure if this is "OK" but worked for me. Ran good tire up on some more 2X4's (acutally more than I thought I would need) and pulled off flat, and had to put more 2X4's under good tire to raise in order to get spare on. After that I know now where my jack is. Won't do it again that way.
(To cheap to buy new)
1990 37 ft 5th wheel that hasn't moved since 1996 (our best home)
1997 33 ft trailer (winter home in much warmer climate)
2005 25 ft M/H (our "stand up B" for traveling)
smkettner
Posted: 05/30/12 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
+1, loosen the lugs first though.
675 watts solar
JIMNLIN
out here
Posted: 05/30/12 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I jack from the axle tubes next to the U bolt or the U bolt itself on std leaf spring axles. I've jacked axles up to 10k using this method.
Which ever method you choose make a dry run at home. Some folks found out the hard way those trailer aids or ramps didn't raise the other axle with the flat tire.
'97 Park Avanue 28' 5er 11200 gvwr two slides
wfreeth
Guelph, Ontario
Posted: 05/30/12 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
I had to change a tire recently at the campground and finally was able to use my Trailer-Aid. Lucky my friend had a bottle jack as the Trailer aid would not lift the tire off the ground. So I just gave it away to my Brother-in-law.
2006 Dodge Ram Megacab Laramie 4X4 Hemi
2004 Four Winds Classic 28BH-M5
Pullrite Superglide 2700/Firestone Ride-Rites
Drive a Hybrid, I need your gas!
hyattjlbb
Minot, ND
Posted: 05/30/12 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, bottle jack and U-bolts as others have stated.
2011 Jayco Eagle 365BHS
2007 Chevy Silverado CC/SB 2500HD, Max & Alli
Beautiful Wife of only 17 Years
Boy - 15yrs, thinks he's 20
Boy - 8yrs
