RV.Net Open Roads Forum: What transmission does my 04 suburban 2500 have?
Search only in Tow Vehicles
 > What transmission does my 04 suburban 2500 have?
Turnkey Brent
Nokomis, IL
Posted: 05/31/12 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
I just purchased a (new to me) 2004 Suburban 2500 with the 8.1 liter big block, 4wd, and 4.10 gears. The transmission is a 4 spd tranny. Which one did GM put in these trucks.
Greg Bunting
Port St. Lucie, FL
Posted: 05/31/12 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have the '05 2500HD truck, and the owners manual says it is an Allison.
MudChucker
Niverville Manitoba
Posted: 05/31/12 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
the diesels will have the alison... gas engine will not...up until 07 you will have the 4L80E transmission.
2005 PILGRIM 274RL 5SS
2007 GMC Sierra 2500HD SLT 6.0
CKNEK
White Rock, B.C.
Posted: 05/31/12 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
The 8.1L in the pickups came with the Allison. The Burbs got the 4L80E.
07 GMC CCSB Duramax with a few goodies.
KD4UPL
Swoope, VA
Posted: 05/31/12 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Nailed it.
bartlettj
Forest Grove, OR
Posted: 05/31/12 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
If you still have the RPO code sticker (a sticker with lots of 3 character codes on it) in the glove box, you can look here to decode them:
http://lonestarthunder.com/m_rpo.php
This will tell you what drivetrain options, axle ratios, seat styles, radio type, pretty much everything.
BenK
SF BayArea
Posted: 05/31/12 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
clicky to Wikipedia GM 4L80E tranny info
Gear ratios
2.48 First
1.48 Second
1.00 Third
0.75 Fourth, OD
2.07 Reverse
-Ben Picture of my rig
Gale Hawkins
Murray, KY
Posted: 05/31/12 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
We have that one in our MH and they are good transmissions. I would recommend a bucket flush using 14 quarts of Dexron VI from WM or better. On some Escalade forum there is a good right up with pictures. Two summers ago we did both the Blazer and Escalade one Sunday afternoon. Pans were dropped the time before.
Turnkey Brent
Nokomis, IL
Posted: 05/31/12 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks ya'll, dont know much about the 4L80E, but everything else on this burb was exactly what we wanted and looking at it and driving it ya can't tell it's not a new vehicle. I am really looking forward to towing with it.
APT
SE Michigan
Posted: 06/01/12 07:47am Link  |  Quote  |  Print  |  Notify Moderator
CKNEK wrote:
The 8.1L in the pickups came with the Allison. The Burbs got the 4L85E.
Yep.
Congratulations! I looked for about a year to find a 03-06 8.1L/4.10 low mileage Burb in good condition. Only found a handful across the country I would have purchased, but ended up getting a new one. It's a great TV! Not many problems to worry about. Replace the receiver it is is the OEM one.
I think the 4L85E came in 2003+, a bit stronger than the 4L80E.
* This post was edited 06/01/12 09:09am by APT *
2012 VW Passat TDI
