RV.Net Open Roads Forum: Travel Trailers: Groaning during cornering from hitch area
 > Groaning during cornering from hitch area
Beacher50
Wisconsin
Posted: 06/02/12 10:48am Link  |  Quote  |  Print  |  Notify Moderator
I have noticed recently (camper has been in storage since last august) that when turing corners, I can hear groaning for the hitch area. Is this normal?
Thanks in advance.
mtofell1
Oregon
Posted: 06/02/12 10:52am Link  |  Quote  |  Print  |  Notify Moderator
In many cases yes. It's happened to me before and I've taken my setup to a shop because I was concerned and they said everything was fine.
Of course, check out all the connections and be sure everything is tight. You might spray some WD40 on various areas to see what quiets it down. That can at least let you know where it's coming from so you can check that area extra carefully.
rgolding
Southern Illinois
Posted: 06/02/12 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Do you grease the trailer ball? How about an anti-sway bar? The load equalizer bars will grown and protest at low speeds and tight turns.
Beacher50
Wisconsin
Posted: 06/02/12 11:17am Link  |  Quote  |  Print  |  Notify Moderator
rgolding: thanks that is what it is I'm sure.
jesse.m.jm
Portland, Or
Posted: 06/02/12 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
I would not use WD-40, it's a solvent, not a lubricant. If you are going to lube, get some hitch ball lube, it's usually a white grease, won't attract dirt like WD-40 will.
2001 26' Prowler Lynx TT
2009 Dodge Durango TV
2012 - 25 nights out so far
catdaddyxx
Dumas, TX
Posted: 06/02/12 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto. I use Reese Hitch Ball Lube
I have noise from where the two W/D bars slide into the hitch if I don't lube them.
2010 29' Jayco, Jay Flight 26BH First real camper
1960 Montgomery Ward popup with slide out galley.(Restored in 2010)
2004 Ford, F150 4x4 lariat 5.4L V8, 3.73 gears, pipes, FIPK, tuner.
Many many mods to the truck
mister_d
Southeast, MI - hardly qualified to be a
Posted: 06/02/12 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
I could swear I've read that you are NOT to put WD-40 or any type of lube on your bars. The FRICTION anti-sway device will no longer work without the friction.
Our Adventures
2011 F150 4x4 Ecoboost 6.5 SCREW 3.73 Max Tow
2011 Lacrosse 296BHS video tour
Hensley Arrow
Me '77 DW '78
DD '04 DS '07
Terryallan
Foothills NC
Posted: 06/02/12 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Do not under and circumstances grease the Sway bar. It will render it useless. Growning, and popping, shows it's working.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
aftermath
Washington State
Posted: 06/02/12 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
This is simply not true. The folks at Equalizer have said to lightly grease the L brackets to reduce the groaning. I can't speak for other brands, but it is OK to add a little lubrication to the WD bars on an Equalizer hitch. I have been doing it for years without issue. If you don't believe me, contact Equalizer. I know this is counter intuitive but it is safe and will not render your hitch useless.
2008 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Prodigy Controler
anaro
Mebane, NC
Posted: 06/02/12 11:50pm Link  |  Quote  |  Print  |  Notify Moderator
Groaning and popping is normal and according to reese can be quieted with some vaseline. It may only be used on certain areas so check your owners manual.
2009 Ford F250 Lariat Crew Cab 6.4L diesel 4WD
2011 Crossroads Zinger ZT26BL
Reese Dual Cam
4 nights camped in 2013!
21 nights camped in 2012!
27 nights camped in 2011!
