Mike Hohnstein
Germantown, Wi
Do your self a HUGE favor and replace ALL the fusible link you can find with appropriate circuit breakers. Have down this on several P-30s and it's the truth. A circuit breaker will reset and in my world makes it much easier to find a short or over loaded circuit.
Clif-Smith
San Antonio, Tx
ok. what size breaker for the Aux Radiator elec fan?
2003 Holiday Rambler Vacationer, 8.1 vortec, Workhorse W22, 34', 2 slides
Current Weekend Warrior
Clif-Smith
San Antonio, Tx
anything wrong with putting a new 25 amp "blade" type in-line fuse. Really circuit breaker out of the question. no room and I don't want it under the hood. I suspect that the 15amp fuse was probably too small and contributed to it getting hot and eventually blowing. probably 30 amp fuse would be better.
wolfe10
Clif,
What size wire goes to relay and on to fan.
Fuses are sized to protect wiring.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
Clif-Smith
San Antonio, Tx
looks to be 14 or 16 gauge. probably 16
Brian in Michigan
S.E. Mi.
My relay is right on top of the fan housing. I found one day while checking it my test light I could get it to come on by putting the test light on the sensor side of the relay.
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS, Thorley Headers B&M trans cooler. Auto meter hooked to output of trans. Flowmaster mufflers recurved distributor Still Keepin on Truckin((((Was 7.5mpg Now 8.75mpg ))))
Clif-Smith
San Antonio, Tx
fixed. I just replaced the old wiring inline blade fuse with a new 'sealed' one with 25 amp fuse. works like a charm.
