RV.Net Open Roads Forum: Fifth-Wheels: Battery Switch Adds a little 5th Wheel Security
 > Battery Switch Adds a little 5th Wheel Security
kab449
PA
Posted: 06/05/12 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
rich and char wrote:
BiggerBen wrote:
kab449 wrote:
My fifth wheel has a GPS tracking system hidden inside so I don't really worry.
That's a great idea.
Thats great for recovery ,after you have been violated. But what about prevention ?
As stated before: if a thief wants what you have he will figure out a way to get it!
2011 F250 Lariat,SRW,Crew,6.7TD,ShortBox
2012 Montana 3750FL
Reese 18K Elite/Hidden Rails
stickdog
29.820224, 81.94542
Posted: 06/05/12 11:29pm Link  |  Quote  |  Print  |  Notify Moderator
Replacement insurance.
9-11 WE WILL NEVER FORGET!
04 HitchHiker DA LS 33.5 RLTG
09 F350 CC DRW 4X4
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Jonny B
Sacramento
Posted: 06/06/12 08:14am Link  |  Quote  |  Print  |  Notify Moderator
okay so what's to stop them from using the manuel hand crank? I agree with kabb449 if a thief wants it he/she will find a way to get it. I have a battery cutoff and my landing gear controls are in a locked compartment. but again easily pried open with a crowbar or a just use a standard trailer compartment key. either way does me no good when the manueal hand crank access is in plain sight on and easily accessible. I dont worry about it. life is to short.
BiggerBen
Alberta Canada
Posted: 06/06/12 08:25am Link  |  Quote  |  Print  |  Notify Moderator
A home security salesman put it best, if they want it, they'll get it. The point of security is to make your place look less attractive to break into than your neighbor's. Same thing goes for the RV, I guess. A pin lock is a visual cue that might make a thief choose another unit that is less work to steal. However, as mentioned, if they want our unit, they'll get it. Cutting power to the landing gear is another good idea to slow them down.
2005 Kustom Koach Legacy LW275
2005 Dodge Ram 3500 CTD SRW
DW, Sadie and Lucie (our dog and cat)
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/06/12 08:36am Link  |  Quote  |  Print  |  Notify Moderator
A receiver hitch pin lock installed into holes drilled in the landing gear legs would keep the landing gear from being able to be operated, either by the hand crank or by electric motor. Together with a quality welded steel (not cheap cast aluminum or pot metal) king pin lock, that should deter most thieves. You could go a step further and put tire boots on the trailer tires. I keep a tire boot on my truck every night.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
45 ACP
Posted: 06/06/12 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Along with the excellent suggestions as to cutting off battery power and pulling fuses, I use this kingpin lock:
Yep, it ain't cheap compared to the typical $20-30 jobber out there. Then again, my 5'er wasn't cheap either.
There are ways to get around kingpin locks, even "unpickable" ones. I too believe in the concept of "make 'em look for an easier target"
2012 Ford F-350 6.7L 4x4 Lariat CC DRW
2011 Blue Ridge 3025RL
larry barnhart
wenatchee. wa usa
Posted: 06/06/12 11:01am Link  |  Quote  |  Print  |  Notify Moderator
We have a 12 volt switch and a landing gear switch inside the basement. I thought this was a standard thing but after reading the above posts I was just guessing.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
djousma
SW Michigan
Posted: 06/06/12 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Might as well just put the RV up on cinderblocks, and take the wheels off too. Some of you must live in some pretty high crime area's. For me, If they want to steal the trailer, go right ahead. That's what insurance is for.
'04 Layton 2940 30' GVWR 9900#
2011 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Sterling Gray Metallic
Dpopps
michigan
Posted: 06/07/12 12:53am Link  |  Quote  |  Print  |  Notify Moderator
My unit also came with a battery shut off inside the locked basement. But my rig like I am sure many others, have spring loaded quick release front landing gear. It would take me no time to back my truck under the 5 er with my air bags empty. Hook on to it, inflate my bags to raise the landing gear enough to pull the spring landing gear part up and drive off.
valhalla360
No paticular place.
Posted: 06/07/12 06:36am Link  |  Quote  |  Print  |  Notify Moderator
I suspect stollen 5th wheels are mostly going from dealers where there are lots of rigs and lots of trucks going in and out and it's easy to lose track of who's who.
If I see a different truck pull up to the neighbors rig and start hooking up at a campground, I'm probably going to wander over and say howdy.
A simple pin lock will discourge most theives while in storage but i would be much more worried with a standard travel trailer. Not many casual thieves will have a 5th wheel hitch handy. Anybody with a 1/2ton has a reicever hitch that will get them 10 miles down the road where they can figure out what to do with thier loot in a more leisurely setting.
Tammy Mike & the Bilge Rat (AKA: Diego)
Ford F250 7.3L
1997 Sunnybrook 27' 5er
1995 Gemini Sail Catamaran 34'
Full Time spliting time between boat and 5er
