RV.Net Open Roads Forum: Class A Motorhomes: awning clamps
stacy50
wi
Posted: 06/05/12 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
i have a class a coach.i heard awning can blow off.
anyone use an awning clamp.
im worried about drilling holes in the side panels hidden
wires or who knows what, leaks
klm
SIOUX FALLS, SD
Posted: 06/05/12 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
http://awninglock.com/model.shtml
I don't know how to make that link clickable, but it should give you some ideas of what is available. I have a manual a & e awning, use the awning lock - no drilling into the rv, that was important to me. I am a fulltimer, travel all over the US, and have never had the awning unfurl - so I guess the awning lock works.
'02 KOUNTRY STAR DP
2012 HONDA FIT "PUMPKINMOBILE"
GILLIGAN- 1ST MATE CAT - 3 HR TOUR
powderman426
ohio
Posted: 06/05/12 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Clicky
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
dneill
milton, fl
Posted: 06/07/12 07:14am Link  |  Quote  |  Print  |  Notify Moderator
I checked out that website. Definitely going to look into it. Although I have never had the awning come loose while driving, I don't want to risk it. I have seen awnings tear up when people have left the awning out when a storm came through with high winds. Not a pretty sight. So, I never leave my awnings out when I know a storm is brewing.
Clay L
Sioux Falls, South Dakota
Posted: 06/07/12 07:50am Link  |  Quote  |  Print  |  Notify Moderator
This one is cheap and requires no holes to be drilled. You can get the parts at any hardware store.
You can see the instructions HERE
I have used one for several years. It would take one heck of a side wind to overcome it.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
jtfcons
Washington State (The dry side)
Posted: 06/07/12 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
I made a similar setup for my rig. Same, except I drilled and pop-riveted the D rings to the roller ends rather than hose clamps, and I used a plastic covered steel cable rather than the chain. The cable ends are formed into loops and secured with the aluminum things that you clamp in a vise to fix them in place. Has worked well for me and is easy to use.
* This post was last edited 04/10/13 05:46pm by jtfcons *   View edit history
John & Sharon, 2 Daughters, 2 Sons-in-law, 5 GK
Scottish Terrier (Chloe)
1997 HR Imp., 38CDS, 1 Slide
325 Cummins C8.3Mech., MD3060, EBw/Coast.Sw.,
Toad-98Tracker 4X4 or 03GMC Envoy 4X4, Excallibar TB, Pressure Pro TPMS, Henderson Mot. Ctrl. Units
