RV.Net Open Roads Forum: Travel Trailers: orientation of stablizer jacks
 > orientation of stablizer jacks
aruba
Alberta
Posted: 06/05/12 10:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Is it ok to mount the stablizer jacks parallel to the frame? Therefore 12 and 6 o'clock. The mounting plate of the jacks that I bought are too wide to mount in 6 and 3 o'clock position as found on most trailers. Any problems with doing this?
Thanks.
opnspaces
San Diego Ca
Posted: 06/05/12 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
Not really, you might get a little more side to side wobble from them.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
sharker6
fulltime KY, NC, FL, MA, TN
Posted: 06/06/12 06:42am Link  |  Quote  |  Print  |  Notify Moderator
I think you'd get a lot more side to side movement with them mounted parallel to the sides of the trailer. Almost to the point of not helping much at all. The jacks, under load, aren't rigid enough in that direction.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
usmc616
Orange County, New York
Posted: 06/06/12 07:03am Link  |  Quote  |  Print  |  Notify Moderator
They should extend off the sides to ensure maximum stabilization for side to side movement
SEMPER FI
Joe,Joyce 4 kids & 3 dogs
2004 Ford Excursion LTD 4x4 V-10 3.73 Gears, Hellwig Swaybar, Bilstein Shocks & Steering Stabilizer, Roadmaster Active Suspension, Super Duty Tow Mirrors
Reese Dual Cam & Prodigy Brake Controller
2010 Jayco G2 32BHDS.
prichardson
Lafayette, La
Posted: 06/06/12 07:50am Link  |  Quote  |  Print  |  Notify Moderator
I have found that if you mount one pair facing fore and aft and the other to the sides it helps in the stability both ways.
five'er
Canada
Posted: 06/06/12 07:53am Link  |  Quote  |  Print  |  Notify Moderator
What kind of jacks? Scissor or Stab? Where are you mounting them? Front and rear extreme? As a side note some of the trailers I've had have had the "Mounting plate" as you put it overhang the RV frame rails.
rgolding
Southern Illinois
Posted: 06/06/12 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I have seen some trailer scissor jacks mounted on the diaganol at the corners. Not how I've mounted ours, but I can see the advantage. Different angles, to me, prevent the domino principal.
Almost all the trailer jacks I have seen welded to frames over hang to some degree as far as the mounting plate to the frame. I'm guessing for optional mounting opportunities.
TUCQUALA
Kennewick, WA
Posted: 06/06/12 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Our Jayco came with the jacks mtd lengthwise due to the frame height from the ground and the length of the jacks. The jacks would have stuck out from the side of the TT if mtd crosswise on the frame. We have not noticed any more movement from this mounting than from the previous trailer which had the jacks mtd crosswise.
As many will agree, the most effective method of minimizing movement is chocking the tires!
'10 Jayco JayFlight 24FBS
'99 K2500 SUBURBAN 7.4L
'03 EXCURSION V10
WENONAH Sundowner 17
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 06/06/12 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
I have never understood why they are not mounted at 45* angles. By doing this it should keep the trailer from moving in any direction.
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
johntank
Oxford, Ms 38655 USA
Posted: 06/06/12 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Don
I have seen some mounted that way (on about a 45 degree angle) but don't remember the brand.
