RV.Net Open Roads Forum: Dinghy Towing: 4 wheel drive veh to tow
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  Vehicles
 > 4 wheel drive veh to tow
tadpole2
Alba, Tx
Posted: 06/07/12 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
We now have a 31 foot Class C and are looking for a 4 wheeler drive crossover or something to tow to Colorado to drive around off road with. What are you suggestions.
tadpole2
dalehelman
Liberty Lake (Spokane) Wa.
Posted: 06/07/12 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Jeep Wrangler
Dale & Sandi
2006 Jeep TJ 4.0 w/33s 4" lift
2008 Winnabago Adventurer 38T
Liberty Lake (Spokane) WA.
DIY Manual replacement for Workhorse Auto Park emergency brake.
Stay In Play Duo Toad Braking System
Fishinghat
Western Washington, USA
Posted: 06/07/12 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
We tow a Hummer H3. It's a nice highway car and a very capable off road vehicle. Towing is very simple. All you do is press and hold a button for 10 seconds. You don't leave a key in the ignition. I use a Roadmaster 9000 braking system and a Blue Ox tow bar. The "baseplate" is simple. You just replace the two front tow hooks with receivers.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
MPond
Thousand Oaks, CA
Posted: 06/07/12 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
dalehelman wrote:
Jeep Wrangler
x2
We love our Wrangler. Headed back to Colorado for more trail riding again this summer.
2003 Country Coach Intrigue, Cummins ISL 400
Toad: 2006 Jeep Wrangler Unlimited (LJ) toad, with just a few mods...
Other rig: 2005 Chevy Silverado 3500 Duramax Dually / Next Level 38CK Fifth-wheel Toy Hauler w/ quads, sand rail, etc...
mowermech
Billings, MT
Posted: 06/08/12 07:12am Link  |  Quote  |  Print  |  Notify Moderator
dalehelman wrote:
Jeep Wrangler
X3
But, if a more "civilized" vehicle is desired, either the Jeep Liberty or the Grand Cherokee. Just make sure it has the transfer case with "NEUTRAL" selectable.
Personally, while the 2012 Wrangler is nice, and the V6 engine is peppy, (my son has one), I like my '06 better.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
The Texan
Meridian, Idaho
Posted: 06/08/12 09:24am Link  |  Quote  |  Print  |  Notify Moderator
I guess everyone missed that he would be towing with a 31' class C, so heavy toads are out.....
My suggestion is a Suzuki or Tracker, in the 04-06 year range. These are fairly comfortable vehicles, are true 4x4 and IMO are little mountain goats. The also tip the scales way under the others suggested, can be found for a reasonable price and tow set ups are easy to find and install. We towed a 1999 Suzuki Vitara till it was rear ended while attached to the RV and then towed a 2003 Suzuki XL-7 for a couple of years. Both were excellent toads.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
MPond
Thousand Oaks, CA
Posted: 06/08/12 10:22am Link  |  Quote  |  Print  |  Notify Moderator
A stock wrangler TJ has a curb weight of 3,092-3,832 lbs depending on options. A first-gen Jeep Liberty is 4,033 lbs, and the 2nd gen is slightly lighter at 3,985 lbs. The first gen Grand Cherokees were 3500-3900 lbs, and the current model is 4,261 lbs.
Many class C's have 5k towing capacity. I don't see the problem...
The Texan
Meridian, Idaho
Posted: 06/08/12 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Most 31' C's have a frame extension welded on and that limits the tow weight, usually to 3500#. Also, most 31' models are close to maxed out on CCC and that also limits the GVCWR. When you talk class C, there are many things to look at, not just hook up and tow.
RV Volunteers CONUS
Full-Time - Park City, Kentucky
Posted: 06/08/12 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
Got the 2008 Jeep Liberty new, 34k miles, used throughout Big Bend for 3 months, Amistad, Charleston and Cape Hatteras.
Has served us well.
2006 Allegro 34WA, Workhorse W20
2013 Chevrolet Sonic LTZ
2009 Blue Ox Aventa LX
2009 Break Buddy
Swagman XC-2
Roadmaster Dual 2" Drop Receiver
VOLCONUS
RV Volunteers Trip Journal
mowermech
Billings, MT
I towed my '06 Wrangler Rubicon Unlimited with the Tioga 29H that we had, E350 based, 460 V8.
No trouble; nothing bent; nothing broke; no accidents, incidents or occurrences; nobody died or was injured!
We even went over Marias Pass on Highway 2, then drove up the hill to Hungry Horse Dam, across the Dam and went to Lost Johnny Point Campground.
And back.
Several times.
By the way, the Jeep is NOT stock. With the added iron, and the 30 gallon gas tank, it is somewhat heavier than a stock vehicle.
Do I recommend that other do what I have done? Absolutely NOT!
I am merely pointing out that it CAN be done, it HAS been done, and it WILL beo done again, probably many times.
Each of us has to make up our own minds about what we can and/or should do.
Good luck.
