RV.Net Open Roads Forum: Tech Issues: Smoke detectors going off without cause
 > Smoke detectors going off without cause
RVcrazy
Puyallup, WA, USA
Posted: 06/10/12 06:07am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone have any ideas of why our house smoke detectors would go off in the middle of the night 2 nights in a row at the same time? The carbon monoxide detector is fine. The lights on the alarms are all on in the various rooms. There is no noticeable smoke in the air.
roam1
Gulf Breeze FL
Posted: 06/10/12 06:14am Link  |  Quote  |  Print  |  Notify Moderator
are they smoke only or smoke & CO2?
are the wired together or independant?
if independant and both go off, you propably have smoke or CO2, find it!
just guessing.....
RVcrazy
Puyallup, WA, USA
Posted: 06/10/12 06:54am Link  |  Quote  |  Print  |  Notify Moderator
The ones I'm talking about now are in our home, not RV. They are hard wired in to many of the rooms and have batteries for backup. CO2 detectors are separate and are fine.
robsouth
Near Atlanta, GA
Posted: 06/10/12 08:01am Link  |  Quote  |  Print  |  Notify Moderator
Why would anyone have a carbon dioxide detector. Maybe you meant CO detector?
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
RoyB
King George, VA
Posted: 06/10/12 08:07am Link  |  Quote  |  Print  |  Notify Moderator
We used to set them off in the missle silos in central Arkansas with a well directed "passing of gas"... Sure got the attention of the missle site personnel hehe...
The things young AIRMAN do...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
rvluversnc93
Thomasville NC
Posted: 06/10/12 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Home hardwired smoke detectors are set up so when one goes off so do the others. You may have one bad head and its causing them all to go off. Also the new more sensitive one's can be activated by dust, microscopic bugs, ETC.. so taking them down one at a time use compressed air on them and repalceing the back-up batts. may cure the problem. If not one head may need to be repalced. If your uneasy in doing this call an electrician and they should be able to handle it.
Happy Camping !!
Derek - FD Battalion Chief
Teresa - Technology Assistant
Hers - 11 Dodge Charger
His - 04.5 Dodge Ram 2500 CTD Q-Cab
(Real Trucks Don't Have SparkPlugs)
2011 Canyon Trail Fiver
Jer&Ger
Kuna, ID.
Posted: 06/10/12 08:33am Link  |  Quote  |  Print  |  Notify Moderator
We had all of ours go off one day at the same time. We finally tracked it down to the fact that the batteries were low on all and just a a little dust caused one to go off and that somehow caused the rest to go off too. We cleaned and replaced the batteries, never happened again! Hope this helps, Jerry
P.S. These were hardwired with battery backup also.
Jerry & Gerry, our pets (dogs), Byron, Coco, & a new member, Jake
1984 Chevy G30 Leprechaun
ejforwood
Littleton (Denver) Colorado
Posted: 06/10/12 09:10am Link  |  Quote  |  Print  |  Notify Moderator
How old are they?
They have a useful life span!
Jerry & Dottie
98 Bounder 34V, 99 F-53 Ford V10 chassis
06 Saturn VUE 4I
Captain_Happy
Abilene, Texas
Posted: 06/10/12 09:14am Link  |  Quote  |  Print  |  Notify Moderator
In todays world of house wiring and all the electrical code changes (not all for the better either) all the smoke detectors are wired together, so when one goes off, they all go off. I was an electrical contractor back in the 80's, and that's what we did then in those years. 40+ years as a working electrician was enough. Don't get me started on all the new code changes, just more to protect the stupid people on the planet.
roam1
Gulf Breeze FL
Posted: 06/10/12 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
oops! another old brain f*rt!
