RV.Net Open Roads Forum: Eternabond tape = Dicor tape??? Camping World
 > Eternabond tape = Dicor tape??? Camping World
roam1
Gulf Breeze FL
Posted: 06/10/12 11:40am Link  |  Quote  |  Print  |  Notify Moderator
I called CW and asked if they had Eternabond. They answered yes, come on down. I drive an hour in the rain and they point me to a Dicor tape that he said was Eternabond relabled. When I do a search on the CW website for Eternabond all that comes up is the Dicor tape. Is this a bait and switch? I did not want to apply any type of permanent tape without making sure it was the real mccoy. Anyone know if they are the same?
thanks!
rolnhome
Casa Grande, Az
Posted: 06/10/12 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
From my research they are made by two different companies..
Your results may vary
We're in Arizona
Weathertodd221
FL
Posted: 06/10/12 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
ABC roofing supply sells the Mulehide brand which I know for a fact is relabled Eternabond. There is an ABC supply in Pensacola.
Dicor stuff needs 24hrs to set?? Pass.
past-MIdirector
Michigan
Posted: 06/10/12 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Same stuff but made by different companies. Camping World stocked Eternabond until Dicor came out with there's. Used both, they apply, stick, and last the same. I've found no difference.
fordsooperdooty
Posted: 06/10/12 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
EternaBond is a patented, propriatary Micro-Encapsulated adhesive tape that is not sold under any other brand name. DiSeal Tape is a "wannabe" substitute.
Camping World doesn't carry EternaBond...WalMart does.
Per Dicor, DiSeal is "water resistant".
The fact is that EternaBond can be used and installed in the rain, and even underwater in a a swimming pool.
roam1
Gulf Breeze FL
Posted: 06/10/12 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
I've read so much good about the brand name Eternabond that I don't want a substitute, I'll try WalMart
Weathertodd221
FL
Posted: 06/10/12 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
you are incorrect. I can send you the proof via PM if you'd like.
Weathertodd221
FL
Posted: 06/10/12 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
roam1 wrote:
Thanks
http://www.mulehide.com/acrobat2/literature/10.00701.pdf
roam1
Gulf Breeze FL
Posted: 06/10/12 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Weathertodd221 wrote:
roam1 wrote:
Thanks
Thanks but..............just got back from WalMart with enough to do my job!
SCVJeff
Santa Clarita, CA.
Posted: 06/10/12 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
I'd like to see that too since there is a CW 10M from here. I looked at the link you posted and there is no mention that it is sold under license or re-branded.
Jeff - WA6EQU
