LowRyter
OKC
bigred1cav wrote: OK, help me. How do I get meat to smoke on a small LP grill without heating the meat to done without the hours needed to properly smoke a shoulder, say? Or ribs, hell i'm easy.
Use St Louis cut for your ribs and use a dry rub.
wrap some hickory wood in foil and let it smoke. Keep adding wood chips. Turn the heat down to about 250, indirect if possible, let it go for 3-4 hours. The skin will break apart on the ribs when you pick them up with tongs, you'll know they are ready.
They should be good enough that you might not want sauce on them.
Similar approach to shoulder. You'll need to cook it longer.
John L
WW SL 2805 5th Wheel
2004.5 Chevy 2500HD Allison Duramax X Cab
Moto Guzzi V11 Sport, Moto Guzzi EV California and Suzuki 1200 Bandit
mike4947
N. Syracuse, NY
The problem is the OP posted about a SMALL propane grill. Not a lot of area so you can use indirect heat, for most of them a way to turn them down to the temp needed. Not to mention also not a lot of inside volume with the top closed to fit the meat; much less have indirect heat..
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
They say you learn by your mistakes, in that case I must be a genius.
SCVJeff
Santa Clarita, CA.
He did?
Jeff - WA6EQU
mike4947
N. Syracuse, NY
Sorry, just used to typing OP, it was a post by bigred1cav
Super_Dave
Sacramento, CA
I've watched a couple shows of the new season and not real excited about them so far. The show jumps from them putting the meat on to turning it in with little to no insight to how they prepare and smoke their meat. The previous shows seemed to have more informational content while not giving away any secrets.
Truck: 2006 Dodge 3500 Dually
Camper: 2007 Eagle Cap 850
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
kscaddo
bigred1cav wrote: You Ohio and Mi folks. I bought 50lbs of Mesquite at Anderson's for $15.00
Come on down to Texas, I've got mesquite for the cutting. Don't use it for everything though.
Regards
2010 Gulfstream Gulfbreeze 26QBS
2012 Ram 3500 4X4 Cummins
Henry Fleming the dog.
bigred1cav
ohio
kscaddo wrote: bigred1cav wrote: You Ohio and Mi folks. I bought 50lbs of Mesquite at Anderson's for $15.00
Regards
I like Apple and Hickory but Mes also makes flavorful a good smoke.
No Mes to cut in Ohio and people get tight lipped when you go in their yards and cut down an Apple tree.
kscaddo
bigred1cav wrote: kscaddo wrote: bigred1cav wrote: You Ohio and Mi folks. I bought 50lbs of Mesquite at Anderson's for $15.00
Regards
The SIL's folks live in New York. In the past I've traded mesquite for apple & pear wood, which I utilize for pork and chicken.
SWMO
Southwest Missouri
I enjoy it, but I do question their choice of judges. having professionals judge it seems to close to personal taste. You know each of them believe there is but one way. I thought it was better when they had Sapps and the food judge in the mix. Myron is so caught up in himself I find it hard to take much from his comments.
As far as smoking ribs on a small grill? When I did it a couple of times I ran some smoke out of foil, like suggested, on a low fire for about 45 minute and then wrapped them in foil and set them on edge around the edge of the grill for about an hour and a half. You just have to peek to know when they're done, if the bones are sticking out clean they are probably ready.
edited 06/21/12 09:29am by SWMO *
2009 Dodge 3500 Laramie, DRW, 4X4, auto, 6.7L, B & W Companion.
Jayco Designer 34RLQS, Mor/Ryde
