5thwheeleroldman
Is that photo from Disco Chicken a burned spot from a LED light? The excess heat is just what I was trying to get away from.
mena661
5thwheeleroldman wrote: Is that photo from Disco Chicken a burned spot from a LED light? The excess heat is just what I was trying to get away from. If you're worried about heat or other issues, get the one's from Command Elec. I use theirs in my three living room ceiling fixtures (6 LED panels - 510 lumens each) with no problems. If you like I can take temperature readings.
Trojan L16 6V's 740 Amp-hours
RoyB
King George, VA
Does anyone know which ebay china LED Boards are causing the burn out like shown in the previous photos on here...
I originally started using the Command Elwectronics PN 170-111 510 lumen warm white boards and really liked the results until I went camping off the power grid and started getting HDTV interference when using my OTA Batwing antenna. Then i also noticed my Ham Radio, Police scanners, and Noah WX Alert Radios where also picking this RFI signal coming from the Command Electronic boards.
This is when I finally decided to get the ebay china 36-1210 SMD boards which worked just great for me. They do not incorporate the regulator chips thats causes RFI signals and this is what I am using today. They get warm too touch but do not get hot for me....
Those photos sent are real scary to me... Sure would like to know what PN LED Boards was used that burned up like that...
My ebay china boards that cost $4.99 each are still performing great after two years of service now. I only have one board that three LED in a roll that is off. When it a few more rolls quit working I plan on just replacing the $4.99 board with a new one...
Something is amiss here with those china boards that are burning up on some folks... Why are some burning up and other are not. Must be a different PN being used. Would really like to know what the part number is...
The other brand of LED I used here for awhile was the LETRAILER ROUND LEDs PN 921-380 which also exhibits RFI signals..
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
beemerphile1
I'm 57, I'm not a
FWIW those pictures are from a thread started by DiscoChicken regarding warranty claim on a new truck camper. Those fixtures were overheated with the OEM supplied lamps. I wouldn't make any assumptions without verification from DiscoChicken.
Here is the thread;
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26042563.cfm
- Soren Kierkegaard
mena661
My Command Elecs panels gives me some RFI on AM radio channels. No issues with TV, OTA or sat. My LEDTrailerlights bulbs give me NO problems at all.
JiminDenver
Denver, Co
WOW now that's some scary photos, thanks for posting the thread.
I got the impression LEDs didn't do that.
2007/2003 Ford Expedition
Nights camped in 2011 21
Nights camped in 2012 16
smkettner
Mine from superbrightleds.com run warm but far less heat than the incandescent.
I don't think it would burn my hand let alone damage the fixture or adjacent materials.
http://www.superbrightleds.com/T10.htm
I use T10-PCB-CWHP9 (bright white, 120 lumens, 190 milliamp) in the main areas and the T10-PCB-WWHP9 (warm white, 92 lumens, 190 milliamp) in the bedroom and bunk areas.
These are less light and lower current draw. They are plenty bright for us. I might turn on an extra fixture when needed but the lower draw is also important to me.
At $22 they probably are not the cheepest either. Have had ZERO issues in about three years. They just work.
edited 06/13/12 02:54pm by smkettner *
675 watts solar
mlts22
Austin, Texas
It doesn't look like LEDs would do that. I'm guessing if they got hot, they would sooner melt the solder and the substrate they are attached to first before cooking the fixture.
KendallP
Grants Pass, OR
beemerphile1 wrote: The cheap ones seem to have high failure rates if you read the complaints on here. Also make sure you get warm white or you will probably dislike the blue tint on everything.
Links?
Perhaps a few years ago, but I dont hear much of that anymore, personally.
Anyone else?
Not every RVer has $500 to drop down on LEDs. Nowadays 50 bucks will get you pretty far in the way of power savings.
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
Our Camper (with no payments)
pappcam
Saskatchewan
Ummmm..... That is from his original incandescent bulb if you'd actually read the thread.
2012 Flagstaff 27 BESS
2011 F150 XLT 5.0
