RV.Net Open Roads Forum: Technology Corner: Power Outlet For Carryout
 > Power Outlet For Carryout
1dhskier
Sandy
Posted: 06/14/12 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
I just use the outlet in my truck. Once the satelitte finds the signal I then put away the 12 volt plug. You do not have to leave it plugged in once its tracked the signal
gmctoyman
Lake Livingston, Texas
Posted: 06/14/12 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
I put a marine type receptical in the refer compartment for mine.
Dave W. AKA "Toyman"
KE5GOH - On 146.52
RV's ? What RV's ???
Apache Pop-up
Classic GMC Motorhome
07 Leisure Travel Sprinter
Do Boats Count ?
1ed
Northern California
Posted: 06/14/12 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
1dhskier,
I thought it moved from satellite to satellite.
dan-nickie
Grand Prairie, TX
Posted: 06/14/12 11:52pm Link  |  Quote  |  Print  |  Notify Moderator
1ed wrote:
1dhskier,
I also unplug mine most of the time also.
True it does move if you choose a channel that uses a diffent sat, but I have learned pretty much most of the channels we watch are on one sat.
Occasionally I'll need to plug it in to get some of the movie channels from the other sat.
Dan and Nickie, Four Winds 31p, Retired Jan/2011
1ed
Northern California
Posted: 06/15/12 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Just called Winegard Tech Support 1-800-788-4417 and they said if I wanted to watch just one satellite and you received all desired channels from that one satellite it is OK to disconnect, but if you want to watch another channel that is on another satellite then you have to have power.
Devocamper
West Haven CT
Posted: 06/16/12 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
We have direct tV and he dish changes sat's depending on what station your watching you can hear it move when you change channels
08 NU-WA Hitchhiker Discover America 339 RSB
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A
