RV.Net Open Roads Forum: Towing: Towing
Search only in Towing
Open Roads Forum  >  Towing
 > Towing
cinandtim
west chester ohio
Posted: 06/13/12 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Purchasing a lightweight 5th wheel. 7000lb empty, 29 to 31 ft. What would you recommend to pull with? Can I get by without deisel?
APT
SE Michigan
Posted: 06/13/12 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Many gas powered trucks will work well. Are you looking at new trucks? I recommend the shorter axle ratio from your favorite brand (4.10/4.30) with their respective gas motors. If you are looking at older/used trucks with fewer gears in their transmissions, I say get the bigger engine (Ford's V10, GM's 8.1L).
* This post was edited 06/18/12 07:11am by APT *
2012 VW Passat TDI
donn0128
Pronounced Ore-gun
Posted: 06/13/12 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Since dry weight term is totally useless I have to assume that your loaded ready to travel weight (or GVWR) will be close to 10K. Based on that you will have a tongue weight probably in the range of 1100/1200 pounds Too much for a 1/2 ton, so start your search for a 3/4 ton. And at that be prepared to upgrade the hitch platform. Gas motor might work if it is a late model motor. Fuel economy will suck. Diesel would be a better choice. And with diesel you could go back as far as 2004 and still have a capable tow vehicle.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
BarneyS
S.E. Lower Michigan
Posted: 06/13/12 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Donn,
What you have posted sounds to me like information for a regular travel trailer. The OP is purchasing a 5th wheel trailer. His pin weight will be quite a bit in excess of 1200lbs I think. Probably close to 2000lbs or over.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
donn0128
Pronounced Ore-gun
Posted: 06/13/12 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
OOPS! Guess I need to learn how to read.
Cummins12V98
on the road
Posted: 06/13/12 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Get a Diesel, spend your money once. You will want a bigger RV and then you will loose money on replacing your truck. Avoid the used PS 6.0 and 6.4 Fords you will probably end up with someone elses problem. Heard 06 was a good year for the D MAX any year 04 and newer RAM will be fine.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
Rick MC
Long Island
Posted: 06/13/12 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
Don't be hatin' my 6.4 PSD. I have no problems and would put it next to any of my friends trucks (dodge and chevy)!
Regular maintenance is the key. I agree you will want a bigger RV, Don't limit yourself, shop around there are some great deals out there! Good luck.
2008 F350 Lariat DRW 6.4 PSD Super Duty 4.10 Rear
2011 Komfort 3530 FBH
Q5 Curt 20K Slider
2008 F250 Lariat Super Duty Firestone Air Ride Bags {sold}
cinandtim
west chester ohio
Posted: 06/14/12 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the responses, will be purchasing a new truck. Currently have a 28ft coachman T/T that I am pulling with a 07 Yukon Denali and it pretty much maxes out the Yukon. (Not a lot of fun pulling). I own a fleet of trucks so I am familiar with diesel, but was wondering if I could get by with a 3/4 gas powered. I agree loaded weight will be closer to 10K
goducks10
Keizer OR
Posted: 06/14/12 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Watch your yellow sticker on the door jamb. Diesels will have lower payloads than gassers. About 6-800lbs less depending on options. But JMHO if your looking towards 10,000lbs I would be thinking diesel. Theres a guy on here that gave an F250 6.2 mpg report and he was getting 8.2mpg. I would think the diesel will get 2-3 more mpg, and better towing ability. FWIW I read an article on Pickuptrucks.com about an F250 KR 6.7 4x4 diesel that only had a 1972lb payload rating. Thats why I say watch checkout the door sticker rating. With that being said if I was going the gas route, I would look at an F250 6.2 with the 4.3 rear end. Just curious what are you putting in your 5'er to weigh 3000lbs? Dry weight at 7000lbs and you think it will be 10,000lbs loaded.
Cummins12V98
on the road
Posted: 06/14/12 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Meant no disrespect! The fact is a lot of the time when someone sells a rig is because they have had problems and the 6.0 and 6.4 have. If yours has been good you have no reason to sell it.
Agree, treat them good goes a long way, but sometimes you have no control.
Your truck does look good!
 > Towing
