porkchop1221
US
The campgrounds ask that we have this when we are hooked up. I'm a little confused and want to clarify if I need to get something different from what I already have.
I just bought the Rhino sewer kit:
http://www.campingworld.com/shopping/item/rhinoflex-swivel-rv-sewer-kit/44151
So do I STILL need a donut?
Something like this?
http://www.amazon.com/Camco-39322-Water-Sewer-Fitting/dp/B0002F676O/ref=cm_cr_pr_sims_t
or this:
http://www.amazon.com/Camco-39313-Sewer-Hose-Seal/dp/B000BQQWKA/ref=sr_1_1?ie=UTF8&qid=1339612637&sr=8-1
Thank you.
2012 GMC 3500HD, Diesel, Crew Cab Standard Bed, SRW
2013 Cyclone 3010 (to be picked up)
sharker6
fulltime KY, NC, FL, MA, TN
Doesn't look like you need a donut with what you bought. It will fit tight enough.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
dieharder
Ottawa, ON
porkchop1221 wrote: http://www.amazon.com/Camco-39313-Sewer-Hose-Seal/dp/B000BQQWKA/ref=sr_1_1?ie=UTF8&qid=1339612637&sr=8-1
Thank you.
Yes, if they require it, you will need one like this. Should be able to get it at Wally World, though. 99 times out of 100 they won't check, but if you get caught without it, they can kick you out if that's what their rule says.
The main thing the donut does is it ensures a tight seal around the connection, and helps make sure the end doesn't come out of the swear hookup when you pull the lever and the stuff rushes out.
1999 Itasca Sunrise
dupreet
High Point, NC
I think the Rhino you have will suffice. The only advantage the rubber ones have is they do wedge in the sewer pipe making an air-tight seal...not sure if the Rhino seals as tightly.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
rv2go
Fulltime (Knoxville, TN).... or someplace else
Some sewer openings will not have threads. In this case, the donut will make an air tight connection.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
dieharder
Ottawa, ON
dupreet wrote: I think the Rhino you have will suffice. The only advantage the rubber ones have is they do wedge in the sewer pipe making an air-tight seal...not sure if the Rhino seals as tightly.
Todd
It doesn't. I have the same one and everywhere I've been it's still a little loose in there.
4x4Bob
California.
2001 2500 Silverado LS 4x4 6.0, 4.10
2007 Jayco Eagle 288RLS
Cocktails for 6, Dinner for 4, Sleeps 2
End of dirt road, no signs in sight, sun going down: I am not lost, just getting ready to go camping.
porkchop1221
US
Thanks. Is there another word for it? Instead of a donut? I tried to find it at the local Wally World but they didn't have it. I might just get it from Amazon, but only found ONE style and it had 1 star. We are leaving Saturay, so we kinda need one!
Thanks!
dupreet
High Point, NC
Are you near a Camping World or other RV Dealer? Or traveling by one? They are $5 at CW. If you can't get one for Saturday, I wouldn't sweat it too much!
starflyte1
Most any rv parts store (rv dealer) will have one and I bet that the campground that requires one has them for sale. In many years of camping, we have not been required to use a donut but a very few times, but it is a small inexpensive item and if needed, it it really worth it to carry one with you.
