RV.Net Open Roads Forum: Class A Motorhomes: Bilstein vs Monroe vs "Other" Shocks
 > Bilstein vs Monroe vs "Other" Shocks
Gale Hawkins
Murray, KY
Posted: 06/15/12 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
What would a set of four run for the GM/Ford based MH chassis?
Weathertodd221
FL
Posted: 06/15/12 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
The service is $65 per shock if you dont have proof of purchase of your originals.
On my truck... I sent the shocks/axle weights/and curb weight and the type of suspension I was running.
Youll need an RMA to return them so the tech will give you a list of what they need to configure the shocks.
LVJ58
Las Vegas, Nevada
Posted: 06/15/12 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
rvrepairnut wrote:
LVJ58 wrote:
On a Ford chassis I would highly recommend the Koni FSD shock. Bilsteins are great shocks also, but you may find them to a bit stiff for the Ford suspension.
Good luck with your choice and safe travels...
road king are way more superior
Most likely they are, however the Koni FSD's provide the ride quality on our coach we're extremely satisfied with.
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
Gale Hawkins
Murray, KY
Posted: 06/15/12 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
johnjones12345
here
Posted: 12/01/12 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
I would like to try a used set of Bilsteins if someone wants to part with them
