RV.Net Open Roads Forum: Class A Motorhomes: 2007 Coachman Epic 8.1L squealing noise
 > 2007 Coachman Epic 8.1L squealing noise
bhivetravels
Chattanooga
Posted: 06/14/12 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Been on the road a few days. When engine is warm and we come off the interstate and slow to a stop we often hear like a squealing sound, like a loose belt makes. But the sound is not a constant. It does not always happen. Could it be the belt?
Jim and Monica
Maj. USAF Ret. -- High School Teacher Ret.
2007 Coachman Epic - 05 Honda Element
Full-Timing with Meiko and Marlie
wilanddij
CA Desert
Posted: 06/15/12 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Lots of info and knowledge about the 8.1L engine and Workhorse chassis here irv2. Maybe you can search or post you're question.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
KJINTF
Montana
Posted: 06/15/12 07:18am Link  |  Quote  |  Print  |  Notify Moderator
I second taking a look at the IRV2 Workhorse threads
Could it be the Power Steering pump?
If so exchange the stock fluid with a good synthetic
Royal Purple worked great for me it elimated the noise
* This post was edited 06/15/12 07:38am by KJINTF *
Thompson Falls Electronics
Always more projects than time
Weathertodd221
FL
Posted: 06/15/12 07:30am Link  |  Quote  |  Print  |  Notify Moderator
mine was quiet til it started screaking one day. I removed it in 3 pieces. (still intact)
$38 later a new one was installed.
bhivetravels
Chattanooga
Posted: 06/16/12 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I popped over to the rv2 posting and I am trying there. I will check steering pump. Thanks
bhivetravels
Chattanooga
Posted: 06/24/12 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Finally narrowed it down to a/c. If I use the motor a/c the noise will occur after I shut off the engine. I can sto the noise by turning the a/c on? So is it the compressor ?
wolfe10
Posted: 06/24/12 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
No, if the noise stops when you turn ON the A/C compressor, your issue is likely with the A/C CLUTCH. Not an expensive item.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
bhivetravels
Chattanooga
Posted: 06/24/12 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Excellent! Thank Ylou
