RV.Net Open Roads Forum: Class A Motorhomes: Dash Air using hydrocarbon ES-12a refrigerant
 > Dash Air using hydrocarbon ES-12a refrigerant
Jarlaxle
New England
Posted: 06/18/12 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
R-22 is a common refrigerant...most home appliances used it for years. (My refrigerator & both my air conditioners use R-22.) Anyone charging an A/C system with a flammable refrigerant should spend the rest of his or her life with "TOO STUPID TO BREED" tattooed on his or her face.
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
zxer
Eugene
Posted: 06/18/12 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Freeze 12 is still available on ebay. I've used it and haven't had any problems.
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=freeze+12&_sacat=0
Jarlaxle
New England
Posted: 06/18/12 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
I'd never use Freeze-12 (or any of the other witches' brews out there), but at least it's not flammable.
REBGORV
Jefferson, Ohio, USA
Posted: 06/18/12 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
regarding the "too stupid to breed" comment...It fits you !!
R 22 is not a suitable replacement for R 12. It will not work !!
Also see the posts on R 134 " it's not only flammable, but toxic also"
some wise guys don't know when to shut up !!!
Rebgorv
stillthinking99
So Calif
Posted: 06/18/12 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
An Enviro Safe salesman said #12 was compatable with R12 and 134a. Later, after my $8 for a can of it, I read the fine print on the side of the can - Do not mix with any other refrigerants. I haven't used it yet.
Gale Hawkins
Murray, KY
Posted: 06/18/12 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
If the shop has a sniffer some will not touch a non standard gas I have been told.
mike mck
phoenix
Posted: 09/12/12 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Matt_Colie wrote:
Let's face the fact that the reason that HC-12 (propane and isobutane) and other non-freons are illegal in some states is because they work and they are inexpensive. In a vehicle, the fire danger is a joke. If you are involved in a accident that opens the system, all the gas will be gone in short order. OH - By the way - read about R134a, it is not only flammable but also toxic, and the combustion by-products are toxic - too.
As to legality, that is determined by state laws. The EPA thinks it can outlaw it use in most cases, but it does not have the authority to do so. All it has said so far is that it has not the data to advise that it is safe to use and even though it is not classed as a "refrigerant" (it is technically a fuel gas), they are trying to tell everybody that it has to be handled as a refrigerant by a licensed technician and cannot be dumped to air, it must be recovered. (They are hoping this is a stopped as there is no reprocessing available.)
I have been working on old refrigeration systems for years now, and I will never again convert a system to R-134a. If you cannot or do not want to bother with collecting enough R-12, then use HC-12a and never look back.
Still want to change to R-134a (that will be banned in a couple of years because of its global warning potential)? All you have to do is disassemble the entire system and flush every part clean of its original oil and refrigerant. When you are reassembling it, replace every seal and gasket with material that is compatible with R-134a. Then with the system assembled and a new dryer fit, evacuate the system to 0.1mm absolute pressure and hold that for 2 hours minimum. Maybe nobody told you that R-134a will react with moisture and form corrosive compounds. Now, recharge it to spec and you will have an operational system that is about 3/4 the capability and efficiency it used to have.
Decided to try HC-12a??
If the system has been open, replace the dryer and evacuate it to 10mm or so just to get the air out. Refill with HC-12a by the calculated weight. It is lighter than R-12, but the can count works out about the same. The sight glass is usually no help. At a high idle (~1500), the low side should be about 20PSI. Enjoy A/C like you never had before. It will be more efficient and have higher capacity. The HC stuff has no compatibility issues with anything.
Matt - the guy that ran ships too long to put up with Bu115h1t.
Matt
Not sure where your information on 134A came from but it does not require tearing your AC system down. It does require purging the system and adding adapters to the high and low pressure ports. They come with the kit. Start engine and engage compressor and install the 134A with oil additive. Less efficient? yes but here in AZ the air comes out of the vent at 38 degrees. Son is a certified master tech and we have changed over multiple 90's vintage gas and diesel vehicles. Can be done in your driveway for under 40 bucks including freon.
Mike
mike mck
phoenix
sorry double post
Gale Hawkins
Murray, KY
Posted: 09/12/12 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
REBGORV wrote:
My vehicle is a 92, 38' American Eagle J, with a 8.3 Cummins diesel.
I need a recharge on my dash air, currently the original R12.
A product by Enviro-Safe called ES-12a is a hydrocarbon based replacement for R 12, completely compatible with the original gas.
It is flammable, but otherwise a perfect replacement gas.
Has anyone had experience with this or similar products ?? I'm about to try it....So, any feedback greatly appreciated !!!
Rebgorv
With a chassis that close to the change over to R-134a may have been set up new with parts that were R-134a ready. Our 1992 P30 (last year to get R-12) has been converted to R-134a with awesome cooling being the results still years later.
Using non approved gases can cause some service centers to not touch it for AC repairs if in a sniff text they find something other than R-12 or R-134a.
Gale Hawkins
Murray, KY
Posted: 09/12/12 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
rgatijnet1 wrote:
As mentioned, R-12 will work better. I used it in several of my Classic cars and if the system has been checked for leaks, R-12 should last for a long long time so the cost of the R-12 itself is really insignificant.
This mirrors our r-12 results.
We bought a new like 1986.5 Nissan PU in 1987 and about 5 years ago after a few years of not cooling I checked it and it still had 2-3 PSI of pressure so I topped it off with 2 cans for R-12 and last week it was still ice cold. 35 years old and still holding r-12 and cooling well. R-12 can run about 2x the price of R-134a but way mess up a working AC system by using unapproved gases?
I know it is a Nissan giving it a quality edge over most MH chassis.
