RV.Net Open Roads Forum: Dishnet Align for Eastern Arc HD Tricks or Tips?
 > Dishnet Align for Eastern Arc HD Tricks or Tips?
az99
Pa.
Posted: 06/16/12 09:16am Link  |  Quote  |  Print  |  Notify Moderator
I need to help a friend align his new dish for dishnet HD on the eastern arc 3 satellites. Any tricks or tips would be appreciated. Can I use a standard signal strength meter and if so, how do you know which sat you are on?
Thanx
TechWriter
On The Road
Posted: 06/16/12 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Get a good tripod and meter.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
- Solar -- Solar Power
- Water -- Water Filtration
- Blog -- www.rvSeniorMoments.com
2oldman
Winchester WA
Posted: 06/16/12 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
This friend only needs this done once I hope.
az99
Pa.
Posted: 06/17/12 04:56am Link  |  Quote  |  Print  |  Notify Moderator
Yes it is at home. Why is it that bad to do ?
TechWriter
On The Road
Posted: 06/17/12 08:50am Link  |  Quote  |  Print  |  Notify Moderator
If it only needs to be done once, contact a local installer.
BTW, what does this have to do with RVing?
az99
Pa.
Posted: 06/17/12 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Nothing other than I am a member of the forum and this type of technical question is discussed regularly whether it be on an RV or home.
What is your problem?
2oldman
Winchester WA
Posted: 06/17/12 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Bad? No, not just once. But I and others were thinking this was for an RV, and if so, would be recurring. And that would be 'bad' as it's not easy, and you have no experience doing it. An installer should probably be doing it on a home.
az99
Pa.
Posted: 06/17/12 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
So let's assume I am setting it up on a tripod at each campsite. It seems as it should be easier than doing a DirecTV HD SWM dish. As best as I can tell they are all the same band (KU?). It has an output for each sat. Will a standard receiver powered inline meter work?
2oldman
Winchester WA
Posted: 06/17/12 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
These questions I cannot answer - I am experienced with DTV SWM only. I assume it's also relatively difficult with Dish.
CT_WANDERER
E. Lyme, CT
Posted: 06/17/12 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
I would think that if you had a dish for the Eastern Arch Satellite, it should not be hard to set up the dish for that system.
