RV.Net Open Roads Forum: 3/4 ton Gasoline TV, less than 5 years old
Search only in Tow Vehicles
 > 3/4 ton Gasoline TV, less than 5 years old
Page of 5
john b
anywhere USA!
Posted: 06/17/12 10:40am Link  |  Quote  |  Print  |  Notify Moderator
fla-gypsy wrote:
The Ford V-10 is the best IMO of all the gasoline powered trucks. 05 MY and up make 362 HP and 457 Ft lbs of torque and delivers all the torque at 3200 RPM's. It is a proven reliable motor and fun to drive. My 09 F-250 6.8L, 5 sp auto and 4.10 rear is a towing machine.
I currently run a 7.3 diesel but if I were to need another I would look long and hard for a vehicle similar to above poster as it is hard to beat at all levels. Look at all the gas motor homes running on this platform . JMHO jb
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2011 Crossroads Cruiser cf32mk Patriot edit. 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
45Ricochet
North Idaho
Posted: 06/17/12 10:49am Link  |  Quote  |  Print  |  Notify Moderator
ib516 wrote:
If you read the Pickuptrucks.com 2010 HD shootout, they put them all head to head.
Clicky
You must be camping again
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
fla-gypsy
North Florida
Posted: 06/17/12 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
Smart man. Just a side note about RPM's and gassers as I know it scares a lot of folks. Mine makes all of its torque at 3200 rpm's, not 5k. Not much sense in running it higher unless you are pulling up a mountain and need every bit of the HP too.
coolbreeze01
Redding, Ca
Posted: 06/17/12 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Would a loaded 2500, 1994, 4x4, 454 Suburban w/44K miles be too old?
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/18/12 01:20am Link  |  Quote  |  Print  |  Notify Moderator
wolfcat1 wrote:
I have decided against a diesel...don't hate, my choice after much research for what is the best fit for "us".. Who has the biggest, baddest, most reliable 3/4 ton gasoline engine in a reliable platform, doesn't matter if truck, or SUV...Please, no brand wars...just straight up specs, and personal towing experience...
Thnks, Wolfie
2005-10 Ford V10 with 4.30 gears.
Only other one that come close is the GM 8.1 V8 with 4.10 gears.
For brand new trucks, the 2011-12 Ford 6.2 V8 with 4.30 gears is no slouch.
As far as the truck is concerned, I would forget the F250 and get the F350SRW instead. The F350SRW has much higher GVWR (1000-1500 lbs higher), RGAWR (6100 versus 7000) and payload capacity (1000-1500 lbs higher), practically no difference in purchase price, and same physical size and maneuverability as the F250. There really is no good reason to buy the F250 over the F350SRW.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/18/12 01:24am Link  |  Quote  |  Print  |  Notify Moderator
No truck is too old, as long as it has been maintained and repaired properly and it's payload and power specs meet the needs of the owner.
APT
SE Michigan
Posted: 06/18/12 08:32am Link  |  Quote  |  Print  |  Notify Moderator
I highly recommend more gears for the gassers. 5-spd for the Ford V10 (don't think it ever got 6) GM 2007.5+ 6.0L/6-spd. GM's 8.1L was great, and in a pickup mated to the Allison 5-spd, but they are more than 5 years old by now.
2012 VW Passat TDI
gijoecam
Midwest
Posted: 06/18/12 09:24am Link  |  Quote  |  Print  |  Notify Moderator
You are correct for the V-10 Ford never getting 6... The V-10 came with a 5 speed auto, the new 6.4 gets a 6-speed.
Captain Obvious
Utah
Posted: 06/18/12 09:34am Link  |  Quote  |  Print  |  Notify Moderator
jerem0621 wrote:
I recommend to buy a 2wd unless you just "need" a 4x4.
It all depends on where you are at when you go to sell the truck. Here in Utah, you can get away with 2WD, but when its time to sell, no one will buy your truck. They go for thousands less than trucks with 4WD and take forever to get rid of.
I have a 2006 F250 V10. I love it. I tow a 6000lb trailer.
* This post was edited 06/18/12 09:41am by Captain Obvious *
Air E Dawg
Georgia Coast
Posted: 06/18/12 10:36am Link  |  Quote  |  Print  |  Notify Moderator
I tow with a 4x4 V-10 excursion. I will flip 200K miles within the month; no complaints and no issues. Power and performance have been great. My TT is at about 9500# empty.
1982 Airstream Limited
Ford Excursion V10 4x4
Page of 5
