RV.Net Open Roads Forum: Fifth-Wheels: Cold weather advice needed
 > Cold weather advice needed
Joe T.
Newhall, CA
Posted: 06/16/12 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
I have a problem. I need to educate myself on what TRULY is a 'four season' RV.
I have a small business in a town about 50 miles from where I live. I live in Wichtia, KS. It gets REALLY COLD in south central Kansas. Winter before last itgot down to -17F!!!
I need a place where I can spend the nights a few times a week at our shop. Our shop does not have a shower or even hot water. I could add that, but I am thinking about a 5th wheel or a towable instead.
If I do this, I would pour a slab and put in full RV hook-ups. I might even put a 'roof' over the RV.
So, what is needed to have a truly winterized RV? Please educate me.
Thanks for al of your advice in advance.
Joe T.
laknox
Arizona
Posted: 06/16/12 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
Joe T.
Seriously, unless you're planning on using the RV for recreational use in the off time, add a shower and water heater to your shop. You'll be mucho dinero ahead. If you want to go ahead with buying an RV, the pad is a great first step, but you'll also want to fully skirt the FW, including the front overhang. Wind is a killer. You can run an extension cord with a couple 100w bulbs underneath to help prevent tank freezing; heat tape on the water inlet is probably needed, too. Electric heat is much cheaper than propane, so use some of the oil-filled radiator-type heaters to keep the coach warm. You'll want to leave these on all the time. You'll also want to consider a fan to circulate warm air around and will want to keep cabinets open on the coldest nights to prevent plumbing from freezing.
Lyle
1936 John Deere Model A
Old-Biscuit
Across the USA
Posted: 06/16/12 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
All kinds of labels on what is a 4 season
Minimum:
Enclosed underbelly with high insulation value and heat source to tanks/valves/lines
High insulation value in floors/roof/walls
Attic space in roof properly vented to outside
Dual pane windows
Then you will need to skirt bottom of trailer and provide for some type of heat source under the trailer.........100W bulbs/heat lamps
Then you will need an insulated/heated water supply hose.
Insulate/heat wrap your drain line.....and have a convenient place to dump waste when needed
Extra electric heating to supplement the furnace....need furnace to provide for heat to enclosed underbelly etc. So plan on refilling propane tanks frequently or have a 100# propane tank set up. You will still need to take it to be refilled.
Then if you do not plan on staying there every day...you will need to shut off water/drain lines/anti-freeze toilet-'p' traps or keep the place real warm.
Might just be a heck of a lot easier to add that bath/shower to shop.
Cold weather and RVs.......constant vigilance. Not something that can be done hit or miss.
I've been in -14*F in our 5'vr.......handled it OK but we live 5'vr FT so had to make it work.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Finally Fulltiming
Summer: NYS Finger Lakes; Winter: Someplace warm
Posted: 06/16/12 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
I don't believe there is any such thing as a "truly winterized RV".
Basically, an RV is like a tin can. Without intervention such as a furnace or other heating device plus heavy duty insulation, the inside temperature will match the outside temperature.
So unless you have other uses for the RV in warm weather, I think your best solution would be to add an insulated room with a bed, water heater & shower to the shop. More comfort & less cost in the long run.
pianotuna
Regina, SK, Canada
Posted: 06/16/12 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
You will find a good discussion of what would be needed for rv use in cold weather here:
winter camping
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Eycom
32043
Posted: 06/16/12 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
Tongue in cheek advice here, based on winter travel up north. A decent 29-32' four-seasoned 5th wheel, which you would want to skirt, of the 2000-2004 vintage would run in the neighborhood of 20-26G. Plus the cost of a tow vehicle of the same vintage would be within the realm of 14K +/-. During the winter, you'd have to winterize the 5er each time you to left for home or leave the heater on 7 days a week to avoid freezing pipes and tanks. If your choice is the latter, your propane bill is going to look like the national debt. Probably need an extended tank to avoid running out... just in case. You'd also need a tie-in for sewage.
With an average of 105 days below 32° and assuming the shop already has heat, water and electric, it would be cheaper and more practical to add a shower and water heater to the shop. Further, relative to stealth and without knowledge of the zoning laws in the area, it would be less conspicuous to occupy the shop for a couple of nights a week rather than parking a 30' 5th wheel next to the building. JMO.
RVn Full-time
dqdick
Council Grove, KS
Posted: 06/17/12 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Being from Kansas, I can tell you the wind is a bigger enemy than the temperature. 20 degrees and a 30 mph wind, not uncommon as you know, will freeze waterlines in a hurry. I'm with the others. Utility and ancillary costs to use a 5er over a couple of years would be more than adding a small room to the shop.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
sue.t
Ibex Valley, YUKON
Posted: 06/17/12 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Really cold? Gee, we had -45F last winter ... that is chilly.
Climate change means we no longer enjoy the really cold similar to the -76F I experienced as a kid 50 years ago.
sue t.
Pictures from our many RV Adventures to Yukon & Alaska
Travelling with either the 25' fifth wheel or the 8' truck camper.
Coalminer UG
Nakusp BC
Posted: 06/17/12 10:02am Link  |  Quote  |  Print  |  Notify Moderator
If I was going to do this I would look at a Fiberglass Bigfoot unit. A second hand one. They are as close to year round use as you can get.
I lived in a 78 Terry trailer one winter in Canada. I built a small extension on it. I also had a small wood stove. It was very hard but I survived.
As others have said, build a shower etc in shop. You will be better off.
Ches
Served In Canadian Army 1PPCLI
Retired Underground Coal Miner (Gen Foreman)
maniac007
South Carolina
Posted: 06/17/12 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
Follow this HERE It will give you some info as well. I did some camping in Jan of this year, just made sure that my water tank was 3/4 full and used two electric heaters in the 5er.
02 F350SD 7.3 CC DRW, 06 Cougar 314EFS
