RV.Net Open Roads Forum: What were the bad years for Ford diesels?
Search only in Tow Vehicles
 > What were the bad years for Ford diesels?
Page of 9
Thunder Mountain
Buena Vista, Colorado
Posted: 06/18/12 09:38am Link  |  Print  |  Notify Moderator
Not trying to start anything here. Was wondering what years did Ford produce the diesel engines that caused owners so many problems. Also, what displacement and or/name did that engine have?
Thanks in advance.
2007 HR Endeavor 40'PDQ
2012 Rubicon
2012 Keystone Outback 210RS
2013 Ford F150 FX4 Ecoboost
4 Cats
3 Dogs
2 Arctic Cats
1 Bottle of Jack Daniels
ib516
Up here!
Posted: 06/18/12 09:40am Link  |  Print  |  Notify Moderator
Generally accepted to be the 03-07 6.0L.
This might interest you
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
swebber
Brunswick , MD
6.0 during the '03 to '07 model years
Steve Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 2000W Inverter & 4000W gennie's
My Camping Pic's
NewsW
US
Posted: 06/18/12 09:42am Link  |  Print  |  Notify Moderator
All of them since 2003 are bad.
Ditto for every major brand.
Chances are, unless you personally knew the previous owner, it cannot be ruled out in the field without manufacturer proprietary tools and laboratory testing that a used unit:
- ran biodiesel (any % above 0)
- have been tuned, modded.
- properly maintained with manufacturer spec filters, fluids, etc.
The best way is to not own one unless you have to have one for your application.
carringb
Corvallis, OR
The '06-'07 6.0 has some improvements that makes is less problem prone, but only compared to prior model years. It still has some inherent issues which can be $$$ to fix.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
4x4ord
Canada
Posted: 06/18/12 09:48am Link  |  Print  |  Notify Moderator
I think the 06 and 07 6.0's have a pretty good reputation. The 6.4 litre is also a good engine once the emission equipment is taken off and a good tuner is added. But if getting a trouble free used truck is of great value to you I recommend you buy an '06 GM or if you want older than that get an 04 - 05 Dodge.
2011 F350 SRW short box 4x4 CC 6.7 PS King Ranch
B&W TurnoverBall and Companion
2003 Citation Supreme 34 RLTS
45Ricochet
North Idaho
Posted: 06/18/12 09:49am Link  |  Print  |  Notify Moderator
Oh boy pile on time
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
Thunder Mountain
Thanks for the answers. Just what I needed. Looking around for a truck to bounce a small trailer down Forest Service roads, go to the dump, lumber yard etc. Without starting new topic. Can someone tell me which Ford gasser had/has a problem with blowing out the spark plug?
NewsW
US
Posted: 06/18/12 09:52am Link  |  Print  |  Notify Moderator
That is an application for gasoline, not diesel.
downtheroad
Pacific Northwest
"...every major brand?" (are bad)
Really?
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
Page of 9
