RV.Net Open Roads Forum: Truck Campers: AC to DC Converter Question
 > AC to DC Converter Question
Fordman01
North Central Washington
Posted: 06/18/12 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Powermax Boondocker PM3B converter in my used truck camper. I have noticed that the fan on the unit runs all the time even when it is not plugged into 120v. The only way I have found to shut it off is to unplug the two fuses on the top.
So does this sound right or not? Maybe I need to install a diode in line to keep the voltage from getting to the unit? or maybe there is a diode that has gone bad inside the unit? Does anyone have a wiring schematic for one of these units?
Golden_HVAC
Fulltime, CA, USA
Posted: 06/18/12 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
There should be a working thermal disk of some sort that will turn on the fans when the box temperature is over say 130F. Below that temperature, the fan should be off. If you are in a area that is over 110F, then it is possible the fan is running because the temperature range is set to cool, and has a turn on temp near 115 and off at 105, to warm for your region.
You might try wiring in another thermal disk to turn on the fans at say 125 and shut off at 115F. This should solve your problem, while still running the fan before the converter overheats. (135 on and 125 off might also work, but the converter might stay warmer).
Fred.
Old-Biscuit
Across the USA
Posted: 06/18/12 11:38pm Link  |  Quote  |  Print  |  Notify Moderator
That converter uses a 12V DC Thermostatically Controlled, Variable Speed Quiet Cooling Fan........check the thermostat.
Fan should only run to 'cool' unit during hard use.
Only manual I have seen is an installation manual.......
"When mounted inside a cabinet, the cabinet must be large enough to allow dissipation of heated air. Make sure that there is a minimum of 1” (one inch) free air space at each end of the unit so that cooling air can move through the unit properly"
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Fordman01
Posted: 06/19/12 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
The thermostat must have malfunctioned, as it runs no matter what even down into the low 40s. I have learned to plug it in or use the disconnect switch on the batteries as soon as I get home or the next thing I know I have dead batteries.
Thanks for the tip on the thermostat, I will remove it form the camper and see if I can figure it out.
Cheers, Tim
JoeChiOhki
Sauvie Island, OR
Posted: 06/19/12 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
No, it's not right, the fans should only run when the unit gets hot enough to warrant them.
I'd suggest contacting Randy @ Bestconverter.com about the issue (if you bought it from them) and getting set up to replace the converter.
CB Channel 17 Redneck Express
Fordman01
Posted: 07/23/12 11:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the suggestion to contact Randy, we worked out a deal and I have a new converter.
Tim
