RV.Net Open Roads Forum: Allison Transmission - Park Set in Gear
 > Allison Transmission - Park Set in Gear
Becuzz
Canada
Posted: 06/19/12 02:38am Link  |  Quote  |  Print  |  Notify Moderator
Fairly new RVer. On return from wintering south a year ago, I parked my Fleetwood (Allison Trans 4000 with pushbutton shifter) and shut it down. Now, a message on computer indicates simply "Park Set in Gear". The computer does not show a specific code other than that message. How do I get it back to neutral to enable starting ? When I leave turned on, or activate the ignition key to start position, the display goes blank although the red mode light is on. If I just leave the ignition key turned on, the display eventually goes to the cats eyes display.
It all seems so simple, I'm caught in gear, can't get it to shift to neutral and can't start it without it being in neutral. Nowhere in the Chassis manual or Allison transmission manual do I see a description of this problem or direction to reset.
Artum Snowbird
Campbell River, B.C., Canada
Posted: 06/19/12 02:41am Link  |  Quote  |  Print  |  Notify Moderator
Sounds tricky for sure. Have you tried disconnecting the main battery for a while, almost like pulling the plug when everything else fails.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
pulsar
Lewisville, NC
Posted: 06/19/12 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
SpinRite
Research Triangle, NC
Posted: 06/19/12 06:33am Link  |  Quote  |  Print  |  Notify Moderator
A bit of Google-ing produced THIS.
'94 Holiday Rambler Navigator
38', Cummins 8.3 300hp, Allison 3060
pushed by a 2005 Honda Element
ajlowden
Washington
Posted: 07/16/12 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
I just read your post. We just bought a preowned RV and this message just came up on the message center and there is no information any where to be found on how to fix this. What was your solution to this problem.
Thanks
Jim@HiTek
Gresham, OR, USA
Posted: 07/16/12 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
Many times a newbie poster finds a solution and never returns...
If I was in your shoes, ajlowden, I'd disconnect the batteries and let it sit for a while. Don't know if that will help, but it shouldn't hurt anything. It might reset the tranni memory of the previous owners driving style.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
ROYBUCK
Newport NC
Posted: 07/16/12 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
This probaby won't help you, but when I purchased my MH I was told to make sure it was in neutral when I shut it down. Roy
Roy B Coal Miners Son
USMC Ret
Semper Fi
2002 Endeavor 330 ISC 3 Slides
