RV.Net Open Roads Forum: Tech Issues: WHAT YEAR IS IT
 > WHAT YEAR IS IT
ADAD437
New Albany,Ind. USA
Posted: 06/19/12 07:37am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2005 class a on a 2004 ford chassis. For all intent and purpose the owners manual and everything i have read says the park brake has fluid to operate and a check plug. Well on investigation i find mine has the drive line drum brake with cable adjustment and no fluid or checkpoint. So this leaves me curious what tranny i have. I bought the rv new. Just curious. Many thanks in advance.
James,Gail & Pancho
2005 georgie boy Pursuit
Dogbone
Ontario Canada
Posted: 06/19/12 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Your RV is a 2005 but check your ownership, the RV builder buys up so many chassis and it could be a year or even 2 before they use them up, it is a bit of a scam as improvements are made to the chassis, you would have the tranny that was in the chassis made in 2004 most likely.
2006 Holiday Rambler Vacationer 35SBD
36ft Workhorse 8.1
rr2254545
Minnesota/New Mexico
Posted: 06/19/12 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Not really a scam they tell you what the chassis is when you buy it. With 2013 MH coming out in early 2012 how could it be any other way?
I do not see any 2013 trucks out yet.
2012 Winnebago Journey 36M Cummins 360
131 Campgrounds since we retired in July 2009
ADAD437
New Albany,Ind. USA
Posted: 06/19/12 08:44am Link  |  Quote  |  Print  |  Notify Moderator
This is all true but if it does not jive with the 2004 owners manual then it obviously is not a 2004 chassis as represented!
pkunk
Questa, NM
Posted: 06/19/12 09:12am Link  |  Quote  |  Print  |  Notify Moderator
The Ford park brake does have fluid in it for many years. The plug is near the top of the assy and if you open it you will lose some fluid.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
ADAD437
New Albany,Ind. USA
Posted: 06/19/12 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Mine does not have it as i have went over it thourouly.
RLS7201
Some Where
Posted: 06/19/12 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Look at the link. Although the brake assembly pictured is for a 95, it is the same as yours, except for the VSS. The oil plug is clearly shown in the picture.
Richard
Wherever I happen to park
Posted: 06/19/12 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
Run the VIN through a VIN Translator. Amazing what all they encode there.
skipnchar
Topeka or somewhere else
Posted: 06/19/12 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Your title will always tell you the correct chassis year. Before the title is originated the information will be on the certificate of origin. Pretty hard to scam someone by giving them written information about the model year.
Michigander2005
Northern Michigan
Posted: 06/19/12 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 1994 Dutchman on 1993 chassis , Dealer explained why below when I bought but dont remeber why for sure .. I belive state farm uses the the vin # of chassis , State of Michigan uses Four winds
State if Michigan plates it as 1994
State farm insures it a 1993
E350 chassis was made 04/93
Four winds International Manufacture date 6-24-93
 > WHAT YEAR IS IT
