RV.Net Open Roads Forum: Toy Haulers: Ramp door damage
Search only in Toy Haulers
 > Ramp door damage
Y-Guy
Tri-Cities, WA
Posted: 06/20/12 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Delam isn't as a bad as I thought it would be, but the fact the bolts show rust throughout the length is concerning. Have you pulled the hinge back to see how things look inside the bolt hole? Obviously need new bolts, gasket idea may help but I'd also fill the holes with silicone or something to prevent further leaks, but leaving the bolts out may help things to dry out if they are still damp.
Does make me wonder if the water is getting in from above and working its way down the door on the inside.
Our RV: '07 Winnebago Sightseer 35J
Our Toys: Four Winns Horizon 190, Polaris Sportsman 500's & Honda Recon's
Bowhunter61
Glen Rock, PA
Posted: 06/20/12 10:24am Link  |  Quote  |  Print  |  Notify Moderator
OldGreaser wrote:
Have a look at a thread by Hemicbx that started 9/18/11. He's got lots of good photos and a writeup that might be helpful for you if you decide to tackle a repair yourself.
Click Here
Sorry, no link. You can use Advanced Search for Ramp Door with him as the author and it will come up, searching in Toy Haulers.
Mod Edit: Made clickable link
Thanks, I have seen that thread and if I decide to rebuild I will be using that as a reference
05 Dodge RAM 3500 DRW 5.9L Cummins
2010 35' Fuzion 302 Touring Edition II
2009 HD Ultra Glide Classic
2001 Polaris Sportsman 500
2005 Artic Cat 250
1997 Kawasaki Bayou 220
1996 Kawasaki Lakota 300
Bowhunter61
Glen Rock, PA
Posted: 06/20/12 10:33am Link  |  Quote  |  Print  |  Notify Moderator
I did pull the hinges and the whole bar assembly holding the hinges. I then dried out the holes. I then used a tube Blue RTV gasket maker and put it on every hinge where it touches the skin and around all 3 bolt holes. I am then going to caulk around all hinges and the bottom metal door frame.
I am with you on the water coming from above so my next step is removing the two clasp holders that secure the 2 locking bars on each side of the door, this could be another area that water can get in. After that I have looked over the whole top of the door and I don't see anywhere that water could get in around the metal frame.
I'm trying to figure out a good way to do a water leak test with a hose.
Y-Guy
Tri-Cities, WA
Posted: 06/20/12 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like your heading in the right direction with all the steps your taking.
Might put a sprinkler up on a ladder a few feet from the back and see how it goes. Rain can be a real challenge and if you spray directly you may force it in where it normally wouldn't.
d-mac1
Colorado
Posted: 06/20/12 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Very interesting link. What kinda of caulk should be used on the seams and screw holes?
2009 Ram 2500 CTD
2012 XLR 300X10
2006 KTM 450 EXC
 > Ramp door damage
