jeffws
Ladera Ranch CA
What I use......
00 FLHR
03 XR 50
05 CRF 70
03 XR 80
05 CRF 230F
06 Yamaha Rhino
06 KTM 525 EXC
05 F-250 CC,4X4,6.0 PSD
06 Gearbox 295FS
05 Carson 7x10
nayther
Burbank, CA
I picked up some generic stuff at a local store and sprayed it on after I wiped off the grease, kind of runny though. I'll check it again, might take a couple of coats. I hope this works because cleaning them every couple months is a real PITA.
Thanks Jeff.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
BobWanderer
Perris,Calif,USA
nayther wrote: I picked up some generic stuff at a local store and sprayed it on after I wiped off the grease, kind of runny though. I'll check it again, might take a couple of coats. I hope this works because cleaning them every couple months is a real PITA.
Thanks Jeff.
NONE of the anti corrossion sprays are perfect, just better than nothing. I dis-like them because they are so messy, but don't like having problems while were supposed to be having fun.
2008 GMC 2500HD 4X4 DMax CC LB
2004 Thor Wanderer Wagon 247WTB
2006 TE450 Husky
2007 Rhino Sport Edition
derwud
Pasadena, CA
well I ran jumper cables from the batteries to the genset and still same problem.. time to pull the genset!!!
2005 Nissan Titan CC SE 4x4, 2006 Weekend Warrior FS2300
2 Quads, 2 Motorcycle and a '06 Rhino
1 Patient Wife, 1 Crazy child, 1 sweet baby.
RIP Bubba and Toby, we love you.
K6DKO
Sierra Madre, CA
Darryl
I always take my genny to Advanced generator in Azusa
2008 Ford F450 Lariat 4X4 LOADED
2007 Weekend Warrior CR3705
2008 KTM 450 EXC-R
2003 Jeep Rubicon O||||O
UPS Feeder Driver
Ham call sign K6DKO
Formerly KF6PLH
BobWanderer
Perris,Calif,USA
derwud wrote: well I ran jumper cables from the batteries to the genset and still same problem.. time to pull the genset!!!
If it won't start, does it have another starter switch on the Genny and did you try it there ??
Mine would not start from inside, I went outside and removed the Genny cover and the switch was stuck from all the dust, cleaned it up and it started from there. I then unplugged the wire harness and cleaned it with contact cleaned and plugged it back in, now it works from either switch.
Good Luck
ljbsvt
THE OC Baby
when replacing the cables, go to a welding supply store and buy some welding cable and have the swedge on the copper lugs (I solder mine then swedge) - WAY better than battery cables from an autoparts store, and the cable is much more flexible.
2011 F-250 6.7 Lariet CC/SB Loaded
2011 Jeep Wrangler Sport
2007 Gearbox 295FS
Pullrite Superglide
2004 KTM 525 MXC - Mine
2006 Polaris Preditor 500 - Her's
2007 Raptor 700R - Mine
2008 Rhino - ours
Member ASA, CORVA
derwud
Pasadena, CA
ljbsvt wrote: when replacing the cables, go to a welding supply store and buy some welding cable and have the swedge on the copper lugs (I solder mine then swedge) - WAY better than battery cables from an autoparts store, and the cable is much more flexible.
Yes...
I have been around the diag nightmare merry-go-round!! Pulling that PUCKER is my last desperate charge to figure it out...
jeffws
Ladera Ranch CA
derwud wrote: ljbsvt wrote: when replacing the cables, go to a welding supply store and buy some welding cable and have the swedge on the copper lugs (I solder mine then swedge) - WAY better than battery cables from an autoparts store, and the cable is much more flexible.
Yes...
I had to pull mine on my WW because it wouldnt start. I cleaned all the cables even added an extra 2/0 Ground still no start. After I pulled the genny out and pulled the cover I spun the fly wheel by hand then tried to start it and it fired right up. I think for some reason I tried starting it with dead batteries and it locked it up some how?? I put it all back together and never had a problem again. It had over 1200 hours on it when I sold it......
Good Luck D....
nayther
Burbank, CA
Another good service provider in L.A. area is Oliphant's in Van Nuys. Larry is the owner and I've known him for many years. Not cheap but VERY fair and does excellent work, he is authorized Onan repair facility.
