Here's an idea, send that pic to the frame builder and ask them what they think! After all they built it, tested it and have all the necessary data to tell the OP how and what to do.
Me I would take it to a certified welder and have the holes welded closed and ground flush. We do it all the time in the tool trades without any issues, even on I-Beams.
Don
last
edited 07/02/12 11:57pm by Perrysburg Dodgeboy *
View edit history
Perrysburg Dodgeboy 2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
If it's a Lippert frame, they likely haven't done any testing on it and have no engineering data on it to give any kind of educated reply. They slap the carp together and throw it out the door.
SoCalDesertRider wrote: If it's a Lippert frame, they likely haven't done any testing on it and have no engineering data on it to give any kind of educated reply. They slap the carp together and throw it out the door.
Thank you very much SoCal...respect your opinions based on things you've
commented on...others...well just comments out of context to 'me' IMHO
Filed this for futures in case I come across a opportunity to either
purchase a Lippert (won't) or work on one...
-Ben Picture of my rig
My TT was built in 94. I have no idea how to identify the frame manufacturer.
Thanks!
There should be a label on the trailer somewhere that ID's the OEM
and has the trailer ratings. It should look pretty much like the
TV GVWR label info, but for the trailer
Why not ask that OEM about their opinion on what has happened to that
tongue, instead of asking here from us outsiders to their design
info...
Thanks!
info...
Hey BenK, that sounds like a great plan. I will try to ID the frame manufacturer and get ahold of them. If you all want, I can report back with what they say.
Thanks!
info...
Is your A frame a tube frame or a C Channel? There may be another option for your mini ball problem if it is C Channel.
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
