RV.Net Open Roads Forum: Tow Vehicles: Dodge truck VS Nissan Titan
Search only in Tow Vehicles
 > Dodge truck VS Nissan Titan
Page of 5
Danford50
North Carolina
Posted: 06/20/12 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Currently i have a 2006 dodge ram 1500 with the 4.7 2 wheel drive i am thinking about upgrading my tv with a nissan titan, i guess what i would like to know if i would increase or decrease my towing ability by switching to a nissan titan i have a 30 foot keystone passport tt, as of now i can only tow my camper on flat surface road oe road with with a slight evelvationusing my dodge truck. any suggestion as far as a upgrade to a titan would i be able to tow my camper?
Post moved from TT Forum to Tow Vehicle Forum
Moderator - TT Forum
* This post was edited 06/20/12 09:53pm by an administrator/moderator *
KD4UPL
Swoope, VA
Posted: 06/20/12 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
You'd have to look up the tow rating of your current truck and the rating of the Titan and compare them. I suspect they are similar. The Titan V8 probably has more HP but the trucks are similar. If you really want to upgrade your truck for towing purposes I would look for a 3/4 ton truck. Any brand's 3/4 (2500 series) will be a significant upgrade from a 1/2 ton (which is what the Titan is).
Water-Bug
Traverse City, Michigan
Posted: 06/20/12 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure that you have ALL of your trailer specs with you if you go TV shopping. Trailer weight and tongue weight are the most important. Changing rear end gear ratios in your Dodge may help your towing capability on grades but will have a negative impact on fuel economy. Talk to the Service Manager at your local Dodge dealer. If he doesn't know what you're talking about, find a new dealer. Changing rear end gears isn't cheap but it a lot cheaper than buying a new truck.
Exocet
Central NY, USA
Posted: 06/20/12 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Went from a Dakota w/ 4.7L to a Titan. The difference with our old 25 ft (5200 lb loaded) TT was significant. The Titan never broke a sweat in the 6K miles we towed it through the western US. Got tired of listening to the 4.7L screaming along in 2nd gear on any hill we hit (I do understand that's okay, but the DW didn't like it when it woke her up!). The Titan just dropped into 3rd in the same situations.
How much does you Passport weigh? Our current TT is in the 7200-7500 lb range loaded. I wouldn't want much more behind the Titan.
2008 Nissan Titan SE, Crew Cab, 4x4
Long Bed, Big Tow, Roadmaster Active Suspension
2009 Spree 318BHS
Reese Strait-Line 1200#
Tekonsha Prodigy
BillB800si
S.E. MICHIGAN
Posted: 06/20/12 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
Dodge period.
If you can't DODGE em then RAM em.
Happy trails,
Bill B. (Michigan)
2007 Dodge Ram 2500 MegaCab CTD
2014 Keystone Cougar High Country 321RES trailer
Squonk61
Vermont
Posted: 06/20/12 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
I've towed my 19 ft TT with a Dakota 2005 and a 2011 Ram 1500. Big difference! After many years of foreign vehicles, I'm thrilled with the Ram. The new trucks are much different than when it was called a Dodge Ram. In my area, trucks aren't selling and the dealer took10k off sticker before we started negotiating. The question really is Ram or Ford. The Ram has so many great features, Outdoorsman model- that I hope to have it many years. 17 mpg, 12-13 when towing.
Cedarhill
Deep South
Posted: 06/20/12 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
It seems to me you ought to take a look at upgrading to a Dodge truck with the 5.7 liter Hemi. It puts out 390hp and 407 ft-lb of torque instead of the Nissan's 317hp and 385 ft-lb of torque while achieving better fuel economy.
jerem0621
Sequatchie, TN
Posted: 06/20/12 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
30 fter?
Titan is not a significant upgrade imho
I recommend considering a 3/4 ton.
thanks
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
Road Phantom
pa
Posted: 06/20/12 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Ram Outdoorsman and get 21 hwy at 60 mpg, on low hill ground. Towing 4,000 lbs, it drops to 13. It pulls the light trailer as well as my dodge deisel did.
whisperide
Golden Spike area
Posted: 06/20/12 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
Aside from the Nissan only being a 1/2-ton, it has the least-efficient engine on the market. Only 317 HP from 5.6L! And it's the thirstiest too! It might be fun in a new Nissan 370Z ( 560Z? )
'06 GMC C2500HD RCLB gasser 4.10:1, 4L80E, custom camshaft
'84 Trans Am 6.2 diesel, 700R-4, custom Class-3 receiver
'69 F350 dually. GM 6.2 diesel, turbo, 700R-4, NP208 all pending.
Page of 5
