Pete_k
Stantonville Tn
I also always shut the water off out side anytime the camper is there and were not. Seen it happen a few times, and does not take long to flip that hydrant back on when you get back.
Hope it did not do any damage. Now even with the water off ours. I'm thinking did I shut off everything when I set it up in the campground today? We will not be back to it until tomorrow evening.
Pete
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
Old-Biscuit
Across the USA
Sorry to hear of your accident......new trailer and all.
How wet was carpet/floor......the sub-flooring is like a sponge when it comes to water.
Swelling/flaking/falling apart/becoming loose......water can really damage a trailer sub-floor.
Hope it was just a little wet and easily dried out.
But if carpet was wet.....padding got wet....floor got wet.
9hrs. of running out the slide?????
Carpet/padding removed?
We had a water fitting break at water heater while sleeping......flooded living area and living room slide.
Had to rip out carpet/padding and dry sub-floor with heat/blowers.
Didn't get to slide out area soon enough......sub-floor swelled and came apart.
$6000 in repairs.......slide out had to be removed/turned on it's side and new floor installed plus new carpet/linoleum living rn/slide/kitchen,
Water leaks....suck!!!
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
webbfoot
CALLAHAN FL
O,I was in it walked right by it. shut the door in the bed room an when I woke the next morning an opened the door I was wondering why It was so humid. Hate telling on myself but I did it good.lol
firemedic08
North Central PA
Awe come one with a Screen Name like Webbfoot, you probably were looking to go swimming.
Donnie
1994 Chevy 2500 Extended cab
1980 sunline,
rattleNsmoke
Western Conn.
OUCH.......
Mike
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
Far-N-Sweet
Liberty Twp, Ohio
Not a water faucet but had the hose from the washer/dryer combo come out of the drain. Man did that wet stuff up all in the closet and carpet in the bedroom. Lessoned learned don't run washer while fishing. Things could have been alot worse.
Far-N-Sweet
webbfoot
CALLAHAN FL
I got lucky , messed up middle shelf on island , but it's useable an hidden under sink. As far as carpet it kind of went under carpet an stayed on the vinyl floor an exited under slide an onto the tire's
Mile High
Denver, CO
KBfiredog wrote: Every night before we go to bed and anytime we leave the camper, the water is turned off at the valve outside. When u go potty at night, u do not need any water pressure, gravity will take care of it. ...or just kick on the pump and run on tank water to flush, then shut off the pump before you go back to bed.
I realize if you are a long term stay you may not fill your tank, but if you do it's a handy water source accessible from inside the coach.
Every once in a while I forget to turn the hydrant back on when I get back.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
Cummins12V98
on the road
If I am on sewer grey valve is open, the day I leave I will add a few gallons and travel to the next site and open valve. This keeps grey tank nice and clean and avoids your unfortunate accident.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
Mile High
Denver, CO
Leaving the gray open is not a big deal because its just soapsuds and toothpaste. Leaving the galley tank open is a different story, you don't want dried food and grease to build up in there. Having the sink go to the black may not be that bad in the end.
