RV.Net Open Roads Forum: Tow Vehicles: Help----Can't Get Inside Of Windshield Clean
Search only in Tow Vehicles
 > Help----Can't Get Inside Of Windshield Clean
Page of 5
garym114
Bluff Dale, Texas
Posted: 06/21/12 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Sprayway glass cleaner. No more windex!
Gets the inside of the windshield clean.
Twain
Tampa - FL
Posted: 06/21/12 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
I use nothing but paper towels and water.
Early 1999 F-350 7.3 DRW CC, 4.10
(retired from towing) 02 Suburban 5.3 3.73
2011 Passport 290BH - Blue Ox Sway Pro
3 Kids, 2 Dogs, 1 Wife.
slarsen
Indiana
Posted: 06/21/12 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
I have fought this problem for years! I have bought only vehicles with leather interiors for decades, and I think the leather preservatives make this particular problem much worse.
I only recently found the cure:
I use a rechargeable multi-driver tool, one of those tools that vibrate at high speed, with the triangular sanding attachment that uses a hook & loop method to hold sandpaper. Only I don't use sandpaper, I use hook & loop buffing pads which I got from Amazon.
Just spray the inside liberally with any glass cleaner, run the buffing pad over the windshield a few times, noting the tiny bubbles the pad makes in the solution, and then wipe off the resulting 'foam' with whatever you like to use. The key is in loosening all the film, not what you wipe it down with.
The high-speed oscillations cut right through the film on the windshield, and you don't have to work at it as the tool does the real work. You just move it around for about a half-minute per vehicle side.
That's it! No more streaks. For awhile, anyway, until the film accumulates and the game repeats.
By the way, I had planned on using a spinning disk, so I bought 6" buffing disks. Upon reflection, I was concerned that a high speed spinning disk might make permanent swirl 'burn' marks. This works better, I think, as the oscillations are very small, but very fast. Four inch disks might be better, but the 6" disks work very good, and since I have three of them, I doubt I'll get 4" any time soon.
campinginthewoods
Central ILL
Posted: 06/21/12 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
ArmorALL glass cleaner and newspaper. It's what has worked for me.
"Our family is a circle of love and strength.
With every birth and every union, the circle grows. Every joy shared adds more love.
Every crisis faced together makes the circle stronger. "
fcooper
Richmond Hill, Georgia
Posted: 06/21/12 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
I had one vehicle that had so much of the oils on the windshield that I finally used lacquer thinner to wipe it down, then cleaned with windex. Be careful to/ keep the lacquer thinner off the upholstery.
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
Terryallan
Foothills NC
Posted: 06/21/12 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
Bounder Billy wrote:
Safelight auto glass cleaner is the best thing I have ever used on windows or mirrors. They sell it at there stores, or will give you a free can when they fix a crack.
I got Binswanger. Prolly the same stuff.
AND Just plain water on a wet rag doea well also. Wipe it with a wet towel, and then dry it with a paper towel, or dry wash cloth.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
Sloop Smitten
San Marcos, CA
Posted: 06/21/12 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
Have always used newspaper to assure a streak proof finish. Try not to use newspaper with colored print but standard copy with black print. Some of the colored inks are so glossy they do not work well.
1992 Fleetwood Jamboree Rallye 24' M/H
Ford E350 Chassis, 7.5L Engine, E40D Transmission
My other motorhome is a 1978 Catalina 25 Sailboat
Cruising Califonia, Sailing the Pacific!
dbond21201
Jackson, TN
Posted: 06/21/12 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah newspaper would work....if the darned local paper would deliver the one I subsribed to 3 weeks ago :-/
Dianne & Wilmot Bond
West Tennessee
helperzack
Florida - Tennessee
Posted: 06/21/12 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
For all of my windows, home as well as auto, I use a handful of corn starch in a bucket of hot water. Wipe it on with a cloth or cleaning sheepskin, then wipe or squeegee off before it dries.
I even use the squeegee on the front MH windshield inside and out. Makes for a quick job.
Coachmen Mirada 310DS
GreenBananas
Somewhere MO
Posted: 06/21/12 11:04pm Link  |  Quote  |  Print  |  Notify Moderator
K Charles wrote:
Use vinegar and wipe it off with newspaper.
X2
Don't buy green bananas! Do the things you wish you could do, now, don’t wait on them. There just might not be a tomorrow.
Page of 5
