Grodyman
Is there a more efficient, lower power consuming 15K but A/C than the Duotherm that comes standard with most 5th wheels?
I would be interested in finding one that can be run on a Yamaha 2400 generator.
Gman
2011 F250 4x4 CC/SWB 6.2/3.73. 2012 Sabre Silhouette 320FQDS. 2011 Lance 830 Truck Camper.
DrBaker
Oklahoma
What about going with an efficient 13.5 replacement and then add a 9.2 or smaller in the bedroom?
This would add several benefits.
2011 Chevy 2500HD CC/SB 4x4 Victory Red
2003 Crossroads Cruiser CF27RL
Champion Screamer, Reese 16k, and a Blue Status Symbol
jauguston
Bellingham, WA
So would everyone else (-:
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
C Schomer
Buckeye, Az.
Yeh, I'd sure like to see the net btu ratings on these lousy RV AC's! They are terribly inefficient. Low air flow/high DT - strong on the latent load and weak on the sensible load. I need to take some time and call some of the mini-split mfgs and see if they have anything for an RV. I've put some in at work and they are nice - decent seers and so quiet, you can't hear them. Craig
jims1
NC
Heatpump? No idea, just throwing out the idea.
I'm thinking about changing mine to a 15k heatpump.
'06 Ram with a Cummins
Tuned w/ EFI-Live
'09 36MAX1 Carrilite
Me, Alie, and Salie
F105
Keller Texas
jims1 wrote: Heatpump? No idea, just throwing out the idea.
Has the heat pump techlogy (sp) really improved to the point that the system can be used in RV's?
I know the basic principles of the heat pump, but can anyone provide a explantion on how they work in a RV?
F105
Keller Texas
Why do I always get an error message when I use the Spell Check feature?
It says to restart and still nothing happens.
Duck
Miami Lakes, Fl
I'm thinking about changing mine to a 15k heat pump.
I would not get a Dometic heat pump. Have one on my trailer and in the heat position it vibrates the cabinets. Dealer has been working with Dome tic to fix the problem and so far all they are willing to do is to put softer grommets on the compressor.
Don
08-FORD F350 PSD
13 Bighorn 3055RL
jauguston
Bellingham, WA
I don't believe spell check has ever worked here. If you are using Internet Explorer download IESpell. Works great.
Jim
F105
Keller Texas
You could be right. I will notify the Admin. again.
Thanks
