Tanya6520
Ft Pierce, FL
We are in Key West and it is pouring down the rain outside. The bed is stuck in the up position. Get R Done has gotten out in the rain with his trusty wrench trying to fix the mechnism. We will be sleeping sitting up, because he couldn't get it fixed. Does anyone have an idea as to what might be wrong. It is not electrical.
midnightsadie
ohio
I would think there should be away to disconect the drive motor from the assembly leting you manualy puting the bed down.
pulsar
Lewisville, NC
Moved from Forum Technical Support.
Handbasket
Asheville, NC
Check for obstructions under & behind the bed. Then if you don't have the printed owner's manual, go to the RT website, look up your model's manual, and see if there's a way to let it down by hand.
How are you sure it's not electrical?
Jim "Mo' coffee!"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
Tanya6520
Ft Pierce, FL
Now bathroom fan is not working. It was fine during the night
NewsW
US
Do you have power (12V and / or 110V)?
Have you checked fuses?
Handbasket
Asheville, NC
If you're not on shore power, I suspect your coach battery is way down. That would account for both issues. But the bathroom vent may just be a matter of the thermostat being set too far up, if it's got one.
Jim, "Will an exhaust brake make my generator quieter?"
Tanya6520
Ft Pierce, FL
Good idea, will check fuse. We do have plenty of power.
