jmbstudios
Sunny Southwest
I am replacing my 12volt battery with a couple of 6v GC2.
I have found that my converter/charger is not doing its job and won't have time to replace it until I get back in a week.
So I would like to get a trickle charger or smart charger that will plug into my generator to charge batteries during the day.
My local stores are Sams Club, Walmart, Pep Boys, Autozone, Sears.
Can someone recommend a charger for the new golf cart batteries? This will help while I am dry camping. Then I can upgrade my converter.
Me, DW, The Girls 7yrs, and 2yrs.
1999 F350 7.3L Power Stroke Diesel!
2006 Trail Lite 27QBSS
Dont forget the music---
Guild 6 string in my Hand!
mena661
One or preferably two of THESE.
Trojan L16 6V's 740 Amp-hours
jmbstudios
Sunny Southwest
Why would I need two of those?
jauguston
Bellingham, WA
Walmart has Schumacher battery chargers. They work fine. Let your wallet determine how powerful you buy.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
John Wayne
Long Beach, Ca
Just make sure it's a smart 3 stage charger.
John & Carol Life members
01 31'Sea View single slide, F53 V-10
96 Toyota 4-Runner auto 4x4 (Remco, M&G brake system)
Security by Bentley
God Bless
KF6HCH
gbopp
The Keystone State
mena661 wrote: One or preferably two of THESE.
Please explain, why does the OP need two 12 volt battery chargers for two 6 volt batteries
I didn't think you could use a 12v charger on 6v batteries, am I wrong?
smkettner
Save the $110 to $150 and just spend $200 on a converter upgrade from the get go.
675 watts solar
jmbstudios
Sunny Southwest
smkettner wrote: Save the $110 to $150 and just spend $200 on a converter upgrade from the get go.
Well I need a charger for other things anyway, and since I won't be able to upgrade the converter for a few weeks due to scheduling and a vacation I am going to grab a nice charger, then upgrade later.
RoyB
King George, VA
The portable Battery charger of choice seems to be the B&D VEC1093DBD smart-mode charger... This is a 40 AMP model but of course can use the smaller amps as well...
photo from google images
Also since you are getting the 6V batteries you probably wont be able to find a 6V charger so keep in mind that you must charge your 6V batteries connected in series.
I have both here and use then both alot... A smart mode convert/charger and a B&D Vector smart mode portable charger.
The 40AMP B&D is right at the maximum draw from using a 1KW Honda type Generator. I think the 40AMP B&D portable charger draws 785WATTS when plugged into your generator set.
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
smkettner
jmbstudios wrote: smkettner wrote: Save the $110 to $150 and just spend $200 on a converter upgrade from the get go.
Then just get a small 10a or less portable.
Best trickle charger IMO is BatteryMinder+ but kinda weak for actual recharging unless small like motorcycle battery. For actual recharging... the 10 or 20 amp Black and Decker is a good buy. No need for the big 40a with a new converter coming soon.
