RV.Net Open Roads Forum: Kill-a-Watt on modified sine wave inverter vs line power
 > Kill-a-Watt on modified sine wave inverter vs line power
dreamer
Southern Illinois
Posted: 06/24/12 10:59am Link  |  Quote  |  Print  |  Notify Moderator
I got the residential refrigerator installed in the motorhome. Here are the readings I am getting from the Kill-a-Watt meter, any comments as to what I'm reading here?
-------- V-- A-- W-- VA-- Hz-- PF
INV 123 2.2 161 266 60 .59
LINE 113 1.0 114 114 60 .99
The inverter is a Trace 1500W inverter #L1512, modified sine wave inverter. I'm guessing the Kill-a-Watt won't accuratly read the MSW.
Thanks,
dreamer.
* This post was edited 06/24/12 02:06pm by dreamer *
'00 HR Endeavor - 330 Cat
'02 Tracker - Blue Ox
How does it feel
To be on your own
With no direction home
Like a complete unknown
Like a rolling stone? - Bob Dylan
pianotuna
Regina, SK, Canada
Posted: 06/24/12 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
My kill=a=watt unit appears to read the same for all items whether msw inverter or shore power--but the hertz are listed as 15--and my polarity tester has all three lights on.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Wayne Dohnal
Bend, OR.
Posted: 06/24/12 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
I have found the kill-a-watt to be a true RMS device. It's quite possible that a device optimized for sine wave operation will be less efficient with another waveform. If you have easy access to the compressor it could be interesting to see if it runs noticeably hotter on MSW.
2009 Fleetwood Icon 24A
Honda Fit dinghy with US Gear brake system
LinkPro battery monitor - EU2000i generator
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 06/24/12 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
The sampling rate of the meter does not work with stepped sine waves. Like trying to negotiate 2" wide steps with size 14 shoes. The meter may want to tag steps rather than amplitude peak and valley.
Wayne Dohnal
Bend, OR.
Posted: 06/24/12 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
Mex, have you tested this? I've tested mine with MSW and it works very well. Surprised the heck out of me. The only thing I found that threw its readings off was using a CFL lamp as the load.
pianotuna
Regina, SK, Canada
Posted: 06/25/12 05:50am Link  |  Quote  |  Print  |  Notify Moderator
Hi Wayne,
All Mex is saying is that the Hertz reading might not display correctly--which is why it shows my hertz at 15 instead of 60.
Wayne Dohnal
Bend, OR.
Posted: 06/25/12 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi Wayne,
Don, you nailed it. Before digging the hole any deeper I re-tested with a light bulb and a motor. With the light bulb the frequency reads 11 with the inverter, and all the other readings are consistent with shore power. The results with the motor were "interesting". This is a small fan. The frequency with one kill-a-watt was around 6, and the other read "dC". In terms of amps, watts, and VA, on MSW the motor pulled 2/3rds of what it pulls on shore power. It was also pushing noticeably less air. So this particular motor doesn't like MSW but I wouldn't go as far as assuming that all motors react in the same way.
MEXICOWANDERER
Posted: 06/25/12 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Connect load, battery charger, conveter, inverter charger, to AC incoming source, be it generator, inverter, shore power, etc.
Probe AC contacts with inputs...
http://www.ebay.com/itm/digital-Waveform-multimeter-ScopeMeter-10MHz-bandwidth-/330754258141?pt=BI_Oscilloscopes&hash=item4d027d74dd
Compare what you believe you have for A/C power to readings taken from electricity grid power. Notice now high the hump in the AC waveform rises and how deep it sags. Compare AC waveforms. Is it a nice, even, not misshapen undulation?
A tool like this will answer any question you may have about effective area under curve of an AC sine wave, and area under curve of a 60 Hz source is what allows battery chargers to work according to design specification, induction motors to start quickly, harmonic distortion (bad), and even noise in a supposedly clean DC source.
Highly Recommended
Wherever I happen to park
Posted: 06/25/12 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Those figures look proper to me, the higher voltage on the INverter will cause a lower power factor for the fridge. (An inductive device).
I have been told though that the Kill-a-watt does not like running on inverters, (either kind) by folks who claim theirs was damaged by running on a TSW inverter of all things.
Mine is pluged into an inverter powered socket, when I travel it is running on a Prosine 2.0 true sine wave inverter, it's does this when I'm wal-marting or boon-docking or flying-j-ing on my annual hike north or south,
It's 7 years old and no problems yet.
So I don't belive everythign I'm told about them not workign on TSW inverters. I don't believe it at all.
Wayne Dohnal
Bend, OR.
Posted: 06/25/12 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
I'm so amazed at how much capability is available for few $$ in the Asian electronics devices. As to the handheld on eBay, I'm too old and obsolete for the small LCD screens and multi-function push buttons. I like the old-fashioned scopes with single-function knobs to turn, although I do sometimes wish for a PC-based scope with its deep storage capability. While looking at the handheld I noticed some nice used Tek storage scopes for $200 to $300. Pretty darn tempting!
I've found that a digital camera can give new life to an old scope, kinda-sorta providing storage capability. Here's an example (voltage and current) of an Onan Microquiet driving a PD converter. And by setting up the correct trigger with single-sweep, startup events can be captured. Other than a lot of convenience, the only big thing a good storage scope adds is random glitch detection.
In the case of the PD converter, the area under the curve is not nearly as significant as the peaks, which explains why it won't perform well with a lousy waveform, even though the RMS voltage is correct.
