RV.Net Open Roads Forum: Ballpark $.00 for a 40' DP tires set of six?
 > Ballpark $.00 for a 40' DP tires set of six?
pondigger
Wi
Posted: 06/24/12 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Hello...it's me again....what is the dollar cost of a new set of tires on a 40' DP....a range of cost would be great from good to top of the line tires....would YOU....automatically put new tires on a coach that's 8 years old with only 26,000 miles on it....I know it sat in a florida RV park for 5 years when in use and a storage place down there when they weren't using it.....second question...how often do you have to do a brake job on a 40 footer and what's a brake job run?...continuing my research....thank you very much for all your help.....your insights expertise and commentarygreatly appreciated....thanks Pond
UsualSuspect
Saugus, CA
Posted: 06/24/12 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Tires, depends on the age, signs of cracking, damage, etc. The coach may be 8 years, but what are the date stamps on the tires? The tires could be a lot older than the coach depending on how long they sat before the manufacturer installed them, or they could have been replaced 6 months ago, or anywhere in between.
I doubt it needs a brake job at 26K, but before I buy anything used I would have a qualified mechanic check it over. If the seller refuses a mechanical inspection, don't walk, don't jog, run away as fast as you can.
2007 Fleetwood Excursion 40E Cat C7 350 HP
2007 Chev 2500HD D/A Long bed CC
2011 Toyota Tundra
Gone but not forgotten, 2008 Jayco 299 RLS
SpurHntr
Northeast PA
Posted: 06/24/12 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
If your coach has an exhaust brake then it's likely your service brakes will last much longer than you'd expect...assuming the engine brake was used as intended.
Mine get inspected with my annual state inspection requirement. Plus reading up on how to check proper functioning hydraulic and air brakes is prudent. Most CDL course manuals from the dot in your state would be a good place to look/read.
Need more info on your tire size to estimate price.
I just put two new steer tires on the font of my DP installed for about 600 bucks each. Top of the line made this year Michelin xza2 energy 275-70-22.5s
8 years old I'd absolutely replace my steer tires and would replace my rears unless I got a good inspection one on them, 10 years is max limit IMHO with annual inspection after 5 wise.
The truck center inspected my duallies and I was happy with that actual service so I'm holding off on replacing my 2007 build date rears just yet.
'08 Newmar Kountry Star 3916, 400ISL Cummins
'11 Jeep Wrangler Unlimited Sahara
'07.5 LMM 2500HD Duramax Crew 8'
Blue Ox, BB, PP TPMS, BB Buggy, Ranger EV
FMCA 427040
Mandalay Parr
Phoenix, AZ
Posted: 06/24/12 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
About $3000-3600. Definitely put on new ones. 5-7 years max.
I have a Freighter Chassis and they told me the brakes would last for about 200,000 miles. Have them checked at your next service.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
Ivylog
Blairsville, Ga. USA
Posted: 06/24/12 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Never for a brake job and $500/tire mounted if you go with Hankook or Toyo. Not any good reasons to go with Michelin or GY. Actually there are some good reason NOT TO. Search "Goodyear rivering" and "XRV blowouts".
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
The Texan
Meridian, Idaho
Posted: 06/24/12 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
If you shop around, you can find Hankook AH-12, Firestone FS-560 or Toyo tires tires for $450-$500 each, out the door. There is NO reason to put a Michelin or Goodyear on your coach, other than to say you have that brand, when the major tire dealers will tell you that there are other brands that are as good or even better, for RV use.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
smlranger
Virginia
Posted: 06/24/12 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
Just got six (6) Hankook AH-12's 275/70/22.5 for $2,730 out the door.
2007 Country Coach Allure 470, 2012 Honda CR-V toad. SMI Air Force One braking system. Lucy the rescued lab/springer mix; Dixie rescued beagle mix. Smith Mountain Lake, VA
sdianel
Tampa, FL
Posted: 06/24/12 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
We bought BF Goodrich ST230's and are very happy with them. They are mid price. They were recommended by Pat at Pro Tires in Denton TX. He works on Country Coach and Prevost coaches. BF Goodrich is owned by Michelin and the tires are made in America.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
ferndaleflyer
everywhere
Posted: 06/24/12 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
I put 6 Kellys on my DP last year the same size as you mentioned. I forget the exact figures but it was around $1800 and I sold 5 of the take offs for $500. Maybe living in a small town where you know everyone has an advantage price wise in these things.
timebum
Westlake Village, Ca
Posted: 06/25/12 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
If you are a FMCA member you can get M's for 50% off
Art
