Doughboy12
Minnesota
edited 06/27/12 12:05pm by Doughboy12 *
KMx2
Gilbert, AZ
Sounds like your ramp door could use some more traction. Doesn't it have the sandpaper stuff on it? Maybe you could add some outdoor stair treads or a strip of expanded metal or something.
Kevin 40, Kim 29 and holding, Mason 4, and Lily 8 mo
2007 Chevy Silverado Z71 Vortec Max
2007 Shamrock 233
2010 Nights camped- 13 +1 driveway
2011 Nights camped- 8
2012 Nights camped- 6
captjohn57
Bay Saint Louis, MS
I bought the 8" version of these to load my Saturn Sky in my 3905 Voltage. The tail gate rests on the ledge on the ramp. Also very light.
http://www.discountramps.com/trailer-ramps.htm
'13 Voltage 3905 Epic Pkg, Loaded, w/Full Body Paint, 7 Goodyear G614 @110PSI and a China bomb 2nd spare
'08 Chevy 3500 D/A LTZ 4x4 CC Dually
'08 Saturn Sky Red Line- Rides in the Back =-}
'06 Honda 500 Foreman
'10 Custom Club Car Golf Cart- Black n Tan
Dirtclods
Newport Beach
Billieg2
Gone from this forum
That is a great Idea but at $292 a pair I think i can build one out of plywood for under $25. I like the way it goes under the tailgate. Thanks for the idea.
In my life I've spent my money on women, booze, Harleys, guitars and traveling, the rest I just wasted...
2007 Ford F-350 diesel/dually & Sunnybrook Titan KSRV 39-1 Toy hauler 5th wheel hauling my custom Harley
RickSo
Alberta,Canada
I see a lot of ramp door extensions on many trailers loading race cars made from wood and checkerplate.
Rick
2012 Excel W41GKE Wild Cargo Toy Hauler
2008 Freightliner Sport Chassis RHA114
2010 BMW K1300GT
2008 BMW R1200GS
dcmac214
SW OKLA
2009flhx wrote: Hi to all,
I just purchased my first toy hauler--a Raptor 30FS. I find that the ramp angle is too steep.
What are my options in changing ramp angle?
Has anyone had this issue?
"Exciting" barely describes the 1st time I ran the Wing into our Fuzion - very steep & very worrysome for an old goat nearing 70. Backing out was even more of an adventure...the tires slip on the ramp.
Get a couple of milk crates to raise the ramp, one on each side, that may be enough for you. If not, build it up with 2x blocks or an additional milk crate to get it to a comfortable height. A 6-8' ramp that has slots for thin plywood will be easier to ride over than the ramp cross-members, and you'll have someplace to put your feet without worrying about stepping thru the holes. You can make the plywood fairly non-slip by painting it with boat deck paint, has a fine-grain sandpaper-like finish. Better, use good enamel, sprinkle sand over it when still wet, brush excess off when dry, 2d coat of paint and you'll have a non-slip surface even in the rain.
buddyhammond
Central Oklahoma
OldGreaser wrote: No problems going in but on some terrain I lose the ability to touch my feet down while backing off the ramp. Usually I'm looking around for some type of rise in the ground to help me out.
I am 5'8" and load a Valkyrie Interstate in our Raptor 300. To avoid the "no touch zone" I remove the seat from the Valk before going up or down the ramp. (It makes it easier to get the front wheel out of the chock too.)
captjohn57
Bay Saint Louis, MS
Billieg2 wrote: That is a great Idea but at $292 a pair I think i can build one out of plywood for under $25. I like the way it goes under the tailgate. Thanks for the idea.
My set only weighs 26# total. I couldn't see how I could've built a set as strong and as light. My car is a bit heavier than the bikes. Just throwing ideas out there. They are worth every penny to me.
joebedford
Jasper, Ontario
 The only problem with these is that there is no way to level them side-to-side if the ground is uneven. My ramp / door is very weak and needs to be supported evenly - any twist and I expect it will break.
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
