mikeleblanc413
Sour Lake, Texas
I'm continuing the thought process and this leak prevention project and in my Google research of various old forum posts I've noticed that some have first put Dicor and then Eternabond over. Sounds like that might been a very good plan. Has anyone done that?
If you've applied Eternabond, what have you found to be the best product to clean the surface with?
THANKS!!!!
Mike LeBlanc, "The Digital Guy"
Professional Photographer, Retired Art Educator
Sour Lake, Texas
"Digital Guy"
Facebook
Flicker
Gale Hawkins
Murray, KY
Dicor is for short term leak protection and Eternabond is for life time leak protection if that helps.
BradinOhio
Akron, Ohio
I just covered the existing dicor with Eternabond on my last rig, and will be doing the same to our new TT shortly. As for a cleaner, I bought a can or two of the EternaCleaner sold by the same company that makes the Eternabond. The cleaning (prep work) is the key to ensuring that the Eternabond fully adheres to the roof.
Brad ('68), Sandy ('71), Amber (shephard), Niko (shiba inu)
'12 F-150 XLT SuperCrew 4x4 Ecoboost with MaxTow
'12 Flagstaff V-Lite 30WRKSS
'10 Keystone Passport UL 245RB (prior - retired 6/2012)
'07 Rockwood Roo 21SS (prior)
mikeleblanc413
Sour Lake, Texas
BradinOhio wrote: I just covered the existing dicor with Eternabond on my last rig, and will be doing the same to our new TT shortly. As for a cleaner, I bought a can or two of the EternaCleaner sold by the same company that makes the Eternabond. The cleaning (prep work) is the key to ensuring that the Eternabond fully adheres to the roof.
Good information from Gale and Brad...I had read at several other points individuals who had trouble with application until they bought the EternaCleaner...
Joe Hamm
San Jose
Acetone is what Eternabond site recommended when I did it.
Wrong Lane
Fredericton, NB
I used Acetone and it worked well. I cleaned all the old caulking off as well prior to applying the tape.
2006 Damon Challenger 348F Ford V10
2011 Ford Fusion on a Dolly
othertonka
Stockton, CA
And make sure you use a little seam roller to roll the tape to activate the adhesive. Read the directions for eternabond about this process, Do not skip the rolling, if you do the tape might/will fail.
steel roller
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Gale Hawkins
Murray, KY
othertonka wrote: And make sure you use a little seam roller to roll the tape to activate the adhesive. Read the directions for eternabond about this process, Do not skip the rolling, if you do the tape might/will fail.
steel roller
2X
So many miss the fact that Enternabond does not stick like tape. Well it does stick like tape BUT that part does not give a water proof bond and it will come over time.
nicpaige
Ohio
I used acetone, worked like a champ. Went over it once then changed to clean rag and went over again, Applied eternabond and rolled with weighted roller. No more leaks.
magik235
Central Wisconsin
I washed the area with Scrubbing Bubbles then cleaned it with acetone before I applied Eternabond.
1985 Sport Coach http://www.rv.net/forum/index.cfm/fuseac........d/tid/26101292/srt/pa/pging/1/page/1.cfm
