RV.Net Open Roads Forum: Towing: Reese Dual Cam and New TT
Search only in Towing
Open Roads Forum  >  Towing
 > Reese Dual Cam and New TT
relliott75
Kansas
Posted: 06/28/12 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
I too have the DC but have to use a 3 pound sledge hammer to get the bars off the cams. I think the cams are adjusted too tight and are binding on the 'u' at the end of the trunion. Does anyone else have this problem? The TT tows like a dream, tracks straight as an arrow on the highway and in winds, and yes makes pop noises while turning.
2007 Jayco 29FBS / GVWR 8800
2010 Dodge Ram 2500 6.7 CTD MEGACab 4x4 Laramie
Kansas City, Kansas
DW, 2 Kids & 100 pound GSD!
jerem0621
Sequatchie, TN
Posted: 06/28/12 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
You probably have 1200 lb bars. The issue with some of them is the crook is pinched slightly wider than the cams. Simply take a grinder and touch up the sides of the crooks, little spray paint and your issue goes away.
Thanks!
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
mjost
St. Louis, MO
Posted: 06/29/12 07:15am Link  |  Quote  |  Print  |  Notify Moderator
Well, I ordered a DC.. I figure worse case scenario, I don't like it, and buy a Hensley, but from reading here, I don't think that will be the case.
Thanks everyone!
relliott75
Kansas
Posted: 06/29/12 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
You're right, it's the 1200 bars...I'll look at the edges to see if that's it next time I'm out. Thanks for the note!
