RV.Net Open Roads Forum: Travel Trailers: Finally got my truck. Next TT
 > Finally got my truck. Next TT
jimmyriley
Hampton Roads Virginia
Posted: 06/27/12 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Got a '12 Ram Laramie Crew Cab w/ 5.7. Rear end is 3.55. Trying to find out tongue limit. There is general information on the bumper cover for general towing with what looks like the limits for a ball attached right on the bumper. The truck has a Class IV Hitch installed. Ram Site states can tow up to 8500. Wont go near that with the new TT but just don't know what the tongue can hold w/ a WDS. Thinking of a front kitchen and they are a bit heavier up front. Any help is appreciated.
Jim
Jim
07' Trailblazer SS
12' Ram Laramie 4x2 w/ 5.7
12' Cougar 29RBK
eric james
Sioux Falls, SD
Posted: 06/27/12 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Congrats on the new truck. Look inside the driver's door for the payload sticker. Tell us what it says and that will help with your trailer search.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
jrat
British Columbia
Posted: 06/27/12 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
The ram will run out of payload first and that will limit whatever tongue weight you can handle. The hitch should have its max printed on it - one with WD and one without. Without knowing exactly I think the coil rear end on those is good for about 1200-1300# payload. Subtract all your in truck gear and passengers. Subtract the weight of the hitch itself. I bet you end up with a 600-700# tongue weight max.
I had an 04 Hemi crew cab - put airbags in rear to help but my HTT sagged it out with a bed full of stuff!
jrat
That's me, wife and 2 daughters!
2010 Tango 299bh
2010 Ram 3500 Crew cab 4x4 SB Diesel
fla-gypsy
North Florida
Posted: 06/27/12 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
The tongue weight rating should be on the receiver. Do check the paylod sticker (door jamb) to see if you can use it all.
parkersdad
North Carolina
Posted: 06/27/12 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
I have the 2011 and they are great trucks but you may wish you had the 3.92 gears if you pull often. Congratulations on your new truck.
Gravyd
Goshen,Oh
Posted: 06/27/12 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
Max payload 1449lbs per http://www.ramtrucks.com/en/towing_guide/
2004 Alumascape 28SKS
2007 Dodge Ram QC 2500 CTD
B.O. Plenty
Minnesota
Posted: 06/27/12 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Tongue weight you see on the receiver is almost meaningless. It states the weight that particular HITCH is rated for and does not apply to the vehicle. You can get a hitch rated to pull 3500# for a Toyota Corolla. Doesn't mean the car is rated for that. Look in your owners manual, they should have a section that shows all the different combinations and how much you can tow as well as haul.
B.O.
2011 Big Country 3250TS...2010 Ram CC Laramie 4wd Cummins
15k Super Glide, Firestone Ride Rite, TrailAir Tri-Glide
Michelin XPS Ribs. Just say no to Chinese tires.
Twin Cities Mn.
jimmyriley
Posted: 06/27/12 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of great info. Thanks for all the suggestion and comments.
Terryallan
Foothills NC
Posted: 06/27/12 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
Jim
IF it fact your truck in it's particukar configuration is rated to tow 8500 LB. Then the trucks max rated toungue weight, In all likely hood will be 850 LB with a WDH. Most, Manufacturers use 10% of the towing capacity for their rated tounge weight.
Reading the hitch will be useless, and the factory hitch installed on every truck will have the same rating. It's the truck itself you have to find out about. My truck has a hitch rated to 9500lbs, and 950 lb tounge weight with a WDH. The truck will not tow 9500lbs. But another version of it will. So they just use the same hitch for all.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
Cedarhill
Deep South
Posted: 06/27/12 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
If you want the facts, go to the source. The following link takes you to the official RAM towing guide.
Ram Truck Towing Guide
Click on the "Open Details" tab next to the model of truck you bought. You can play around with the number of passengers and use the slider to see the trade-offs between total towed weight and payload. The 8900 pound figure assumes your tongue is weightless. A more realistic figure might be 7400 pounds trailer weight, 2 passengers and 1000 pounds of tongue weight and other stuff in the cab and bed.
Edit: I just bought a 2012 Quad cab with the 5.7 liter Hemi and 3.55 rear axle ratio and 6 speed auto. The power-train is extremely strong. As someone already mentioned, the limitation in towing capacity is related to the smooth riding rear coil springs. For my purposes, the superior ride trumps the higher base towing capacity of the other half ton trucks.
