RV.Net Open Roads Forum: Travel Trailers: DIY Axle Alignment
 > DIY Axle Alignment
BurbMan
Louisville, KY
Posted: 06/29/12 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Anybody use this bolt-on alignment kit? Any comments and feedback appreciated. I don't have an alignment issue that I'm aware of, but I do need the 2" of lift that it provides.
ScottG
Bothell Wa.
Posted: 06/29/12 09:55am Link  |  Quote  |  Print  |  Notify Moderator
I don't understand how it can work if it only moves the outside hangers and not the equalizer..?
Scott, Grace and Wesly
H0NDA eu2000i
BurbMan
Louisville, KY
Posted: 06/29/12 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Adjusting the static hangers fore/aft adjusts the squareness of the axle to the frame. The spring floats on the equalizer anyway because of the movement in the shackles.
ScottG
Bothell Wa.
Posted: 06/29/12 10:09am Link  |  Quote  |  Print  |  Notify Moderator
But the equalizer only moves for and aft with articulation of the wheels (one up or down more than the other). If the wheels are both level then there's no for and aft movement of the equalizer.
tvman44
Southwest Louisiana
Posted: 06/29/12 11:49am Link  |  Quote  |  Print  |  Notify Moderator
A good alignment shop would be cheaper.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
JJBIRISH
Butler, PA, USA
Posted: 06/29/12 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
Trailer life article
click
Tweetys has a installation video… I can’t watch it, my connection is so poor it would takes forever to view…
click
Web site
click
Installation instructions for kit 1
click
Installation instructions for kit 2
click
I think kit 1, and some square tubing, would give you the height you are looking for, strengthen the chassis, and give alignment adjustability…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
BurbMan
Louisville, KY
Posted: 06/30/12 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Ordered the kit, will report back when it's installed.
Wills250psd
walnutcove NC
Posted: 06/30/12 08:43am Link  |  Quote  |  Print  |  Notify Moderator
I hope it works for you. I would like to raise my TT a couple of inches and this may be a good option.
Sampson-Shack
Southern Maryland
Posted: 07/01/12 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have a minor alignment issue and want to do this. Looking forward to the install review..
JBarca
Dublin, Ohio, USA
Posted: 07/07/12 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
Scott,
Take a moment and look at your springs. The front and rear hanger is fixed and controls the position of the spring. The axle cannot move as it is held by that hanger. It is the front and rear hanger that is creating the axle alignment to the tow ball and to the other axle.
The alignment that can be accomplished by the Reico Titan is the front axle is tracking true to the tow ball, (thrust angle) and the rear axle is parallel to the front axle.
It does not adjust for camber or toe angle.
I would declare the Reico unit provides a course adjustment for thrust angle and axle to axle parallelism. If one wants to adjust the axle in this direction in a fine resolution dead on, the use of an adjustable axle seat can give you this. Alko makes one for the larger axles and "some" have made their own home made ones. Looks like this.
Hope this helps
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
