pjb2rlb
Greer, SC
HELP - need suggestions - we are getting ready to leave on vacation tomorrow and wanted to load motorhome today - while shutting door the dead bolt slipped and locked us out - we have had 2 different locksmiths out here trying to open door to no avail. Short of breaking a window - does anyone have any suggestions. We have a key - turns but does not unlock the deadbolt - something is broken in the mechanism. I was thinking of taking door off hinges but the bolt that holds the hinges has rivets on both ends and was unsure how to get them off and if I did could they possibly be replaced.
trnfla
Tampa
search for tri-mark locks there is a way to drill a hole to open the lock
Please say a Prayer for my 5 year old Granddaughter (Discovered she had Leukemia at 9 months), she has been in remission and tests keep coming back clean.
Now 2004 Winnie Minnie 31C
Had 2007 Zeppelin 190 Hybrid,
1999 30' Dutchman Classic FW
NiceCamps.com
barlow46
Edgewater, FL
2007 Fleetwood Excursion 40E Is this your coach?
Does this link help?
http://www.rvshop.com/print_catalogs/trimark/030-0900_tech_pub.pdf
If not, go to http://www.irv2.com/forums/f107/ and do a search for "locked out" or "deadbolt lock". I think you can find some help there. Good luck.
2005 Monaco Dynasty Diamond IV 42'
04 F450, 6.0 auto, 4:30 rear; BrakeSmart; 50 gal aux.tank, 01 HR Presidential 35CKS, 3 slides, axles flipped; TrailAir Pinbox. pin weight 2760. Total gross TV and 5th: 24,060 lbs.
blangen
South Dakota... and everywhere.
I would think you'd have better luck with sliding a slim jim or similar piece of thin metal between the sashes of a window and pushing open the lock or, perhaps, tripping the escape lever on a window. Of course, this assumes you're very familiar with how your locks work (what does what and in which direction, etc.) Just a thought.
Edit added: By "better luck", I'm comparing my option to rivet drilling and door removal. Obviously, the coach-specific post above mine is a couple of steps ahead of me.
trnfla
Tampa
check this thread on where to drill the hole link
Tinstar
McKinney, TX
The lock is broke anyway so just drill it out. You can hold it shut by some other means until you run across an RV supply while on your trip. The locks are not real expensive.
Never pass up a chance to go somewhere
rvrepairnut
bc
Tinstar wrote: The lock is broke anyway so just drill it out. You can hold it shut by some other means until you run across an RV supply while on your trip. The locks are not real expensive.
if its the dead bolt as the OP has stated it has nothing to do with the actual door closing lock so that wont be a problem
pjb2rlb
Greer, SC
Locksmith said drill it out still wouldn't open it.
rvrepairnut
bc
pjb2rlb wrote: Locksmith said drill it out still wouldn't open it.
R U 100% sure its the dead bolt?? I absolutely can not see how a "deadbolt" can in any way self lock?
pkunk
Questa, NM
get one of the local hoodlums to B&E for you. Offer cash.....
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
