padave
Richland PA
Got a new TV....broke down and bought an Ecoboost F150. Question, when adjusting, how do you know how many spacer washers you need? Going from a Titan SWB of 140" to F150 with 157" wheelbase. Do you think that I will need to add a washer or two?
wife and 2 daughters
2012 Ford F150 SCrew 4x4 Max Tow
2011 Lacrosse 318bhs
Equalizer
former:
Nissan Titan
Rockwood Roo 233
Coleman Westlake
pulsar
Lewisville, NC
Moved from Forum Technical Support.
BarneyS
S.E. Lower Michigan
The only way to know is to hook up, measure or weigh, and see. I suspect that it will remain just about the same.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
jmtandem
western nevada
Quote: Going from a Titan SWB of 140" to F150 with 157" wheelbase. Do you think that I will need to add a washer or two?
The wheelbase of the truck has nothing to do with adjusting the hitch. The height of the receiver between the two trucks would be the difference in hitch head height on the shank that might need adjustment. Be certain the trailer is sitting level fully loaded for camping and the spring bars are nearly parallel to the trailers A frame correctly tensioned. Approximately one washer in the head equals one hole in the L brackets for adjustment.
edited 07/01/12 08:29am by jmtandem *
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
'09 299bhs Tango.
eric james
Sioux Falls, SD
Starts on page 17... Equal-i-zer Owner's Manual
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
mkirsch
Rochester, NY
There's no way to know what you need until you try it. The whole process is a bit of trial and error.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
Ron Gratz
full time RVer
padave wrote: Got a new TV....broke down and bought an Ecoboost F150. Question, when adjusting, how do you know how many spacer washers you need? Going from a Titan SWB of 140" to F150 with 157" wheelbase. Do you think that I will need to add a washer or two? I agree with jmtandem that a change in TV wheelbase should not require a change in WDH ball mount tilt or L-bracket height adjustment.
The required load transfer is slightly dependent on distance from TV's rear axle to tow ball.
But, there's probably not enough difference in that parameter, for the two TVs, to make any difference in the WDH adjustment.
If the OP wants to follow Ford's new specifications for WDH adjustment, he might need to remove a washer or two.
Ron
Searching_Ut
Utah
Wheelbase most definately come in to play. We're talking leverage, and distance on both sides of the pivot point are part of the equation. Just follow the directions to which a link has already been provided and I think you'll find it's fairly easy to set up, although you may have to try several combinations to get it just right.
Chuck&Gail
In the Colorado Mountains
The only RIGHT way is to follow the directions. Every vehicle is different.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
Ron Gratz
full time RVer
Searching_Ut wrote: Wheelbase most definately come in to play. We're talking leverage, and distance on both sides of the pivot point are part of the equation.--- Since you mentioned equations --
When the coupler is placed on the ball, the load removed from the TV's front axle is approximately: L = TW*OH/WB
where TW = tongue weight, OH is ball overhang (distance from TV's rear axle to ball), and WB = TV's wheelbase.
For the Titan: L1 = TW*OH1/140
For the F-150: L2 = TW*OH2/157
Then we have to select a criterion for adjusting the WDH. Let's assume we want to adjust the WDH so it restores 100% of the load which was removed from the front axle.
The load restoration is approximately: R = WDF*BL/TTD*(OH+TTD)/WB
where WDF is the combined downward force exerted by the WD bars against the A-frame, BL is the effective length of the WD bars, and TTD is the distance from ball to midpoint between TT's axles.
For the Titan: R1 = WDF1*BL/TTD*(OH1+TTD)/140
For the F-150: R2 = WDF2*BL/TTD*(OH2+TTD)/157
Since we assume the restored load will be equal to the removed load, we have R1 = L1 and R2 = L2. That gives
WDF1*BL/TTD*(OH1+TTD)/140 = TW*OH1/140, and
WDF2*BL/TTD*(OH2+TTD)/157 = TW*OH2/157
A little bit of algebra simplifies the above to:
WDF2/WDF1 = {OH2/OH1}*{(OH1+TTD)/(OH2+TTD)}
If you replace OH1, OH2, and TTD with any realistic values for the OP's TVs and TT, you should see that there is relatively little difference in the theoretical values of WD bar force required for the two TV's. And, what difference there is, does not depend on TV wheelbase.
Ron
edited 07/01/12 02:50pm by Ron Gratz *
