RV.Net Open Roads Forum: Fifth-Wheels: Tire repair or replace?
 > Tire repair or replace?
texn1995
West Texas
Posted: 07/04/12 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
So my last trip out I took a screw in the tread.
The tires are only a year old with about 500 miles on them.
Should I repair or replace the tire?.
Thanks....Erik
/////Camping or Ridding when the AirForce will let me stay home/////
///////2009 F250--2012 Jayco 31.5 FBHS--2012 FXDWG///////
Turbo Diesel Dude
Green Mountain, NC
Posted: 07/04/12 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
Take the tire off and put a hot patch on the hole on the inside is what I'd do. JMHO Others will say" replace" and must have more money than grey matter.
charles weidman
path1
seattle
Posted: 07/04/12 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
depends on what it looks like inside. So when you're getting it looked into make sure the place has what you need in case you have to replace the tire.
(To cheap to buy new)
1990 37 ft 5th wheel that hasn't moved since 1996 (our best home)
1997 33 ft trailer (winter home in much warmer climate)
2005 25 ft M/H (our "stand up B" for traveling)
Wills250psd
walnutcove NC
Posted: 07/04/12 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem with new tires last year. The tire was plugged and seemed fine but then a big knot grew from the same place on the tire. Lucky I noticed it after we got to the campsite and I had to replace it. These ST tires are poor at best. I would replace it. JMO, WILL
amxpress
Clayton, NC
Posted: 07/04/12 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
If the hole is in the tread area, a plug/patch is the BEST way to repair it as shown on this website: http://www.artsautomotive.com/publications/8-automotive/66-tires-patch-or-plug
I've repaired many tires this way with no problems, if it's done correctly.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L denied parole! Yeah!
texn1995
West Texas
Posted: 07/04/12 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
In a car I have patched or pluged. I just wasn't sure about on the trailer. There's a bigg differance in 32 and 65 psi
Chuck&Gail
In the Colorado Mountains
Posted: 07/04/12 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
I've had TT tires repaired with inside umbrulla plug several times. In each case repair outlasted tread.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
cpaulsen
California
Posted: 07/05/12 02:07am Link  |  Quote  |  Print  |  Notify Moderator
Patch if you can and the hole is not that big. I have patched a lot of tires that are filled to 80psi before with never a problem.
cpaulsen
Dave H M
IL
Posted: 07/05/12 06:31am Link  |  Quote  |  Print  |  Notify Moderator
Me, I would take it to the trusted service center and have them evaluate it.
aruba5er
Neenah Wisconsin
Posted: 07/05/12 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Dave H M has got the BEST advise. Why would you listen to a bunch of dummys like us when you can go straight to the experts. Use their advise. Not a bunch of opinions.
