path1
seattle
Very many rear end problems with high mileage RV's?
edited 03/11/13 12:06am by path1 *
(To cheap to buy new)
1990 37 ft 5th wheel that hasn't moved since 1996 (our best home)
1997 33 ft trailer (winter home in much warmer climate)
2005 25 ft M/H (our "stand up B" for traveling)
VintageRacer
Dundas, Ontario
Gears are cheap, probably around $1K installed at a rear end shop. I bought a ring and pinion and did it myself on a chev once, the gear was around $400. Fords are usually really easy, since you can take the pumpkin out and carry it to the shop, you don't need to take the axle out. You are right, though - they last a long long time if the lube gets changed once in a while. The rear gear in my RV (converted MCI) has probably way over 2 million miles on it, and I ain't changin' it!
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
jauguston
Bellingham, WA
Rear ends are probably one of the least troublesome parts of a vehicle. Change the oil at 50,000 miles and use something like Mobil One synthetic. You probably would never need the spare.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
cm
Dillon, CO USA
If you decide to buy it have a shop that does a lot of axle work check it out. Specialty shops that work on a lot 4 x 4s do a lot of axle work. Unless they find a problem with it that will not cost much. They can also tell you what that axle is worth used.
Also make sure the brakes are compatible with your old axle. Or just switch your old brakes to this other axle with new shoes, drums, etc. if needed. Plus it would be a good time to completely change your brake fluid.
SuperDutyMan
Western PA.
Own a rear end shop,if the lube is changed occasionally (70,000mi.)it will last for hundreds of thousands of miles,not to worry....
2011 Palomino Sabre 31RETS,5th Wheel,Triple Slide,4000W Onan Genset
2006 Super Duty,XLT, V10, 6 Speed, 4.10, Tow Command, Tow Pkg. 4X4,Dual Exhaust,K&N,Reese 15K,Air Bags
wandering1
You are worrying about something you dont need to worry about.
HR
ol Bombero-JC
jauguston wrote: Rear ends are probably one of the least troublesome parts of a vehicle. Change the oil at 50,000 miles and use something like Mobil One synthetic. You probably would never need the spare.
Jim
X-2.
Spend your $ on something else.
bucky
Eastern Shore of MD
As long as the T bone wasn't on the wheel it will be ok. But as the others have said, you will probably never need it. Is it posi and yours isn't? Just a thought.
99 K3500 DUALLY 07 JAYCO 345 BHS
recycler
michigan
if it is cheap i would get it can always sell it later because if you ever have a failure those dana 80's are expensive to repair did one last year was $1,500 in parts
elkhornsun
Monterey
I have never heard of a rear differential used under normal conditions, i.e. not for racing, that has failed all of a sudden. When the wear gets to a certain point you should be able to hear a clunk in going into reverse or back into first gear. If it is quiet it is probably OK.
Easy enough to check on the internet to see if your truck and model year tend to have a problem with the rear end. If not then forget about it.
When I had a rear end redone on a truck of mine I had them put in new replacement parts as most of the cost was in the labor.
