RV.Net Open Roads Forum: Navistar loses in court- folly of it own choices
Search only in Tow Vehicles
 > Navistar loses in court- folly of it own choices
Page of 8
hone eagle
essex ontario canada
Posted: 07/04/12 06:31pm Link  |  Print  |  Notify Moderator
linky
Stock drops as they scramble to change to SCR.
Are they toast?
How will this effect Ram/Cummins time table?
2005 Volvo 670 singled freedomline 12 speed
Newmar 34rsks 2008
Hensley trailersaver TSLB2H
directlink brake controller
-when overkill is cheaper-
NewsW
US
Posted: 07/04/12 07:29pm Link  |  Print  |  Notify Moderator
Dodge / Cummins is still got enough banked credits.
But things are changing for 2013:
Ahead of tightening greenhouse gas and fuel efficiency requirements for 2014, the enhanced engines are expected to deliver up to 2 percent better fuel economy thanks to new high-efficiency water, fuel and oil pump systems. On the emissions end, the engines will employ Cummins' Emissions Solutions EcoFit suite of exhaust aftertreatment technologies, integrating a diesel particulate filter and a selective reduction catalyst. On-board diagnostics -- long a part of the passenger car and light-truck markets and employed by Cummins starting in 2007 -- will be spread across the entire engine lineup.
http://www.trucktrend.com/features/news/2012/163_news120321_cummins_updates_diesel_engines_for_2013/index.html#ixzz1zhutXqb7
Now the funny part.
Greenhouse Gas Emissions (aka MPG) regs are tightening in 2014.
They could have simplified things if they went CP4 pump for 2013.
But.. if they delay.. then a redesign has to be done again for 2014.
Massive EGR was a dud... high fuel consumption because it lowered thermal efficiency, and also generated a lot of soot, which means lots and lots of regens.
That is what Cummins customers get for an obsolete and archaic technology. But it goes well with an obsolete engine and an obsolete truck design.
FishOnOne
The Great State of Texas
Posted: 07/04/12 07:48pm Link  |  Print  |  Notify Moderator
Now the funny part.
Does this mean Cummins BlueTec is obsolete?[emoticon]
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Tough"
'16 Sprinter 319MKS "Wide Body"
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 07/04/12 07:57pm Link  |  Print  |  Notify Moderator
Yep that CP4 has been working so well for everyone running it right Bules.....er I mean News lol. The 2500/3500 wil be running the same system that the 4500/5500 are running now starting late December or early January.
Don
2015 Ram 1500 Laramie Crew Cab SWB 4X4 Ecodiesel GDE Tune.
Golden_HVAC
Fulltime, CA, USA
Posted: 07/04/12 08:07pm Link  |  Print  |  Notify Moderator
I was looking at the SuperNova motorhome tonight, and they use the International chassis. I am wondering if they will still be able to offer a diesel engine in that chassis as well?
Or perhaps International can start to offer the Cummins or other brand compliant diesel engines in their trucks. I know that Ford is putting in Cummins and other engines in their class 6 trucks.
Fred.
#40Fan
Colorado
Posted: 07/04/12 09:52pm Link  |  Print  |  Notify Moderator
[emoticon]
And I was thinking that everything you have said was worthwhile to reading.
2013 Arctic Fox 22GQ
2011 Ram 2500 CC LB CTD G56 3.42 Mineral Gray
CumminsDriver
Colfax Calif.
Posted: 07/04/12 11:26pm Link  |  Print  |  Notify Moderator
Ok smart a$$. Since you know everything about everything, what is so obsolete about the Ram except for the DEF that the other trucks have?
2016 Chevrolet/Duramax 3500HD Dually Crew Cab B&W RVK 3700 5th Wheel Hitch
2014 Arctic Fox 29-5T
hone eagle
Posted: 07/05/12 04:32am Link  |  Print  |  Notify Moderator
Makes me wonder if this is the reason for the Ford /Navistar split ?
Did Ford want a more mainstream NOX solution ? Did Navistar balk ?
This started around that time frame.
bucky
Headed home today after 26 days on the road.
Posted: 07/05/12 04:36am Link  |  Print  |  Notify Moderator
Dodge owners are always so touchy. [emoticon]
2005 Cummins 2500 2WD LB quad cab pulling a 2007 Jayco 345bhs. It pulls better than Marcell Ledbetter's mule.
gmcsmoke
Butler
Posted: 07/05/12 04:44am Link  |  Print  |  Notify Moderator
Sig worthy
Page of 8
