joe0508
charlotte
That is the reason i was gonna cover it with enternabond tape.But if i can use the middle marker light somehow to run the cable i might go that route.My main concern with drilling a hole is wiring and creating a leak i cant stop.My fuse box is located close to this area where the marker lights are.
joe money
booty51
houston
Go to a marine supply and buy a clam shell cover to put over cable where it comes out the cap. It looks good seals the hole . Make sure you put calk in it and wipe off the excess after you install it.It will not leak .
fourmat
NJ
I would rather drill a 1/4 hole in the cap and drop the wire down than run it over the roof with 20' of tape Drilling the hole is easy and you will have to drill holes to mount the camera
2009 Challenger
joe0508
charlotte
The clam shell sounds like what i need.I looked on the web at them and they are perfect.Thanks for that info.I just hope i wont have much of a problem snaking the cable down the end cap.
joe0508
charlotte
If i opted to go the clam shell route what size would you recommend when drilling a 3/4 inch hole.
fcooper
Richmond Hill, Georgia
Joe
I think you're making this too hard. Look at the image below, at the top camera in the image. With this type of mount, you drill one hole large enough to pass the camera wires/connectors, mount the camera bracket with two self drilling screws, caulk around the cable, and you're done with the camera. On most motorhomes, the cable will drop down the cavity in the rear cap and can be placed along the frame rail.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
joe0508
charlotte
Ok i will give it a try.Pray that it doesnt leak.Why is the camera in the photo aimed at the sky.
fcooper
The upper camera is not aimed at the sky, but it looks that way with the picture being taken from below the camera.
My monitor has 3 inputs. I wanted a camera for viewing tow bar/toad, and I also wanted a view further back on the roadway to see what's coming up behind the coach. The lower camera in the factory housing is a close up view, and the upper camera shows all lanes from part of the tow car to the horizon.
It's not for everyone, but running two cables is just as easy as running one. Another way to accomplish multiple views is with a camera with pan/tilt feature which requires only one cable run.
I hope you get your system installed. Use good caulk on the one hole and you'll be fine. On most coaches, even if it did leak, it would run down the back side of the fiberglass cap and drip out beneath the coach.
Fred
