While I was at Lowe's picking up some Sta-Bil, there was a product right by it, made by the same people called "Start your engines!". Supposedly it does something similar to Seafoam where it gets added to the gas tank and cleans out the varnish. It also can make old, expired gasoline usable.
Anyone hear of this product, much less use it? It looks interesting, and might be useful come winter when I start boondocking again and start using my generator more often.
I've used it, and I'll give it a glowing review I had a lawn mower that I wasn't able to start. I had tried cleaning the carburetor, and all the usual stuff, without success. Just for kicks, I figured I'd try it....and it started up on the 3 pull!
Like SeaFoam, which cleans and treats the fuel, this stuff also seems to have something that helps with the starting too. I have used SeaFoam for awhile, and also swear by it, for cleaning out the fuel systems, but for some reason, I think that SYE is a bit better for starting....while the SeaFoam is great at cleaning it out once you have it running.
Like a lot of diets, that tell you you will lose weight, if you go on their particular program, in addition to eating less, exercising more, etc.....the SYE tells you to drain the bad gas out of the engine, change the spart-plug, and some other things that would for the most part, help start your engine, so who really knows if there is magic in that can!
To me, it was worth a few bucks!! A lot cheaper than taking the engine to a small engine repair shop!
Bill & Claudia / DD Jenn / DS Chris / GS MJ Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293 The Pets
I am so satisfied with Seafoam I'll stick with it.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
mlts22 wrote: While I was at Lowe's picking up some Sta-Bil, there was a product right by it, made by the same people called "Start your engines!". Supposedly it does something similar to Seafoam where it gets added to the gas tank and cleans out the varnish. It also can make old, expired gasoline usable.
Where does one find the expiration date on gasoline ?
I have been using StarTron enzyme fuel treatment, it is supposed to take care of the ethanol problem in marine engines as well as stabilizing the fuel.
Actually they make so many claims it seems to resemble snake oil but it is supposed to be the latest and greatest additive everyone I know is using it and I have had good luck so far.
Anyone else tried this product?
Dusty
Question of the year!
On the gas cans that I store (for lawnmower, etc.) I date the purchase date. All the other gas gets used up way before it could get 'old'.
