RV.Net Open Roads Forum: Dinghy Towing: Readystop Break Away
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  All
 > Readystop Break Away
tropical36
Southwest Florida_USA
Posted: 07/05/12 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Just wondering how many use some sort of a break away system that locks up the toad brakes in case you lose it all together.
I'm installing the READY BRUTE/BRAKE ELITE and also have the break away as well.
Just looking at this beast, I find it next to impossible to lose anything that's connected to it, but I guess it has happened.
Once I get the READY BRAKE installed, I'll take a good look at installing the BRAKE AWAY system, if deemed necessary.
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal Model 6350 on a 1997 Chevy P32
Chassis_7.4 Vortec Engine_4L80E Tranny_slide_tag axle.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
ronfisherman
SE Michigan
Posted: 07/06/12 05:34am Link  |  Quote  |  Print  |  Notify Moderator
I just installed on my Malibu Maxx. Was not a problem while installing the Ready Brake. Hope I never need it. But a good feeling just in case it is needed.
Kodiak Chassis Class C Forum
willald
NC
Posted: 07/06/12 08:07am Link  |  Quote  |  Print  |  Notify Moderator
I also use the ReadyBrute/ReadyBrake system (won't have any other braking system). And, yes, I also installed the ReadyStop break away system.
Like already said, hope I never have to use it, and don't quite see how I ever will. But, it is good to know that the brakes will be engaged on the towed vehicle if it ever breaks completely free.
Its easiest to install both the Readystop and Readybrake at the same time if you can, rather than going back later to add the ReadyStop. Reason being, both of them route a cable from the brake pedal, its easier to do both cables at once. Thats the approach I'd suggest.
Will & Angela
2 children that love camping, Stephen & Allison
2012 FR Georgetown 351DS on F53 (V10) Chassis
Our Rig
Bobbo
Wherever I park
Posted: 07/06/12 08:24am Link  |  Quote  |  Print  |  Notify Moderator
I also have the Ready Brake Elite. I would never consider towing without the breakaway system.
Bobbo, Linda and the furry kids (1&1/2 German Shepherds)
2007 Winnebago Outlook WF331C on a Ford E450 Super Duty Chassis
2010 Subaru Forester w/BlueOx baseplate & Ready Brute Elite towbar
topflite51
In The Desert of Nevada
Posted: 07/06/12 08:46am Link  |  Quote  |  Print  |  Notify Moderator
As suggested, do it all at once.
David
Just rolling along enjoying life
w/F53 Southwind towing a 87 Samurai or 01 Grand Vitara looking to golf or fish
Simply Despicable
Any errors are a result of CRS.
tropical36
Posted: 07/06/12 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
I probably would have done it all at once, but since I did some mods where it attaches to the brake pedal, I wanted to test all that out first. I made a bracket for the pedal arm and have attached a small pulley wheel that rotates with the pull and a quick disconnect pin for removal. This way the cable isn't attached permanently and when not towing, the cable doesn't go in and out with constant driving use.
Just got it installed before getting rained out and was about to start studying the BREAK AWAY instructions.
So far it's looks to be all pro for this system and according to what I see here for state laws, it's a no brainer, so back to the garage...BREAK AWAY LAWS
tropical36
Posted: 07/07/12 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
OK, READYSTOP Brake away is installed. I removed the brake pedal pad and drilled a couple of holes through the pedal, then made a double loop through them with the aircraft cable and attached a quick disconnect to that. Now both cables can be disconnected and layed away when not in use as a toad. Hopefully this part of the system with never be used.
Tomorrow we'll do the testing and any required adjustments to everything by pulling the Jeep around with my F-150.
