RV.Net Open Roads Forum: General RVing Issues: Strange Problem
 > Strange Problem
GrumpyGator
Middle Tennessee
Posted: 07/05/12 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
I have had my RV at a local campground for a couple of months while my RV Garage has been under construction. During this time all the electric has worked fine.
The garage is done and today I finally got the electric in.
When I plugged in the RV to the new electric... Nothing.
So I turned on the generator for 10 minutes. Turned it off and tried the shore power once more... nothing.
Then I turn the generator back on and let it run while I was doing other stuff in the RV. When I decided to go back to the house I cut off the generator. Then I heard the microwave beep. The shore power was now working fine.
Being a total newbie I'm way over my head. Seems like maybe whatever allows the switch-over from generator to shore power might not be working correctly.
Any ideas?
2012 Nexus Phantom 31P
Yaj
The Milky Way Galaxy (Hartford, WI)
Posted: 07/06/12 12:17am Link  |  Quote  |  Print  |  Notify Moderator
Maybe a bad auto transfer switch. If it does it again give the box a whack with a screwdriver handle. If your not pretty familiar with AC power and hazardous voltage its not a good idea to open up the box on your own.
1996 HR Endeavor LE,Cummins 5.9 230hp, Allison 3060,
Front-Yamaha Enduro, Rear-Honda Helix Geeser Cruiser + 2 bikes,
22ft 1977 Cruiser in tow.
1 DW, 2 kids.
1 old dog, 1 fat cat.
I wasn't thinking this far ahead!
PegLW
SW Missouri
Posted: 07/06/12 04:21am Link  |  Quote  |  Print  |  Notify Moderator
Does your new rig have a built in surge protector? Ours has a two minute delay while it checks all circuits, etc. before the power begins working. Could it be something like that?
Peg
Dave and Peggy
2012 Open Range 345RLS
2012 Ford F350 6.7L turbo
GrumpyGator
Middle Tennessee
Posted: 07/06/12 06:23am Link  |  Quote  |  Print  |  Notify Moderator
I was thinking that it might be the transfer switch...
I have a surge protector, but it is a separate unit. First thing I did was take it out of the loop. No change when I did that.
The good thing is, I'm going to be back at the manufacturer next week for some other minor fixes. Good time for a problem to pop up.
Ron3rd
Upland, CA USA
Posted: 07/06/12 06:56am Link  |  Quote  |  Print  |  Notify Moderator
Call the electrician back out and have him take a look at it.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
Valkyriebush
Yuma/Port Townsend
Posted: 07/06/12 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the transfer switch. Plug the RV in run generator, turn generator off and listen to hear if the transfer box is clicking trying to change over. I just had this problem repaired. New transfer switch.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
MrWizard
Traveling
Posted: 07/06/12 11:09am Link  |  Quote  |  Print  |  Notify Moderator
number one mistake
being plugged into shore and starting generator
at the very least you can cause something to jam , at the worse you blow your generator
already happen to at least two members in the past few weeks
it sounds like the generator side of the transfer switch was stuck, so the shore power side could not engage
always unplug shore before starting generator
always turn OFF generator before plugging in shore power
always make sure A/C units are off, and water Heater is off before starting or stopping generator or plugging unplugging shore power
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
SteveRuff
Bacliff, Texas, USA
Posted: 07/09/12 08:06am Link  |  Quote  |  Print  |  Notify Moderator
MrWizard wrote:
number one mistake
This has always confused me. If this is, in fact, the case then how does the autostart system work? I don't have one yet but I have been thinking about adding a backup system so that my generator and air conditioner would kick back on for my dog if I was away from the coach and the power went off? Of course, way more likely is that a breaker would trip in my coach and the autostart would have no effect, but I guess there is really no way to fail safe every possible contingency.
Both retired. Travel with Nicky the Schnoodle. Son graduated and is teaching high school math. We still love our 2006 34' Allegro Bay XB and have 40,000+ miles on her.
MrWizard
Traveling
Posted: 07/09/12 08:54am Link  |  Quote  |  Print  |  Notify Moderator
AFAIK
generator auto start is there to prevent the batteries from going dead
it sense battey voltage
it's not there as emg backup power to keep your air conditioner going
fact is we this time of year with hot weather we are usually seeing posts from people that want a warning alert system to call their cell phone if power fails an the a/c quits , so their pets are not harmed
Valkyriebush
Yuma/Port Townsend
Posted: 07/09/12 11:10am Link  |  Quote  |  Print  |  Notify Moderator
You can play it safe by unplugging shore power first but the transfer switch is designed to make this transfer plugged in or not. I almost always unplug first. I was only suggesting this procedure as a test.
 > Strange Problem
